Question about Maytag Refrigerators
The control panel on My Maytag refrigerator, model #MFI2269VEB2 does not appear to be working. When I push a button all the lights light up. Any idea how to fix this?
Posted by Robert Baker on
Sanjoy Bose
    New Friend:
Another area to look into is the control panel itself. Due to moisture seeping under the plastic filament the touch buttons / leds may stop working
Posted on Mar 09, 2019
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Posted on Jan 25, 2008
Anonymous
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
Anonymous
  • 30 Answers
SOURCE: front panel on my GE side-by-side refrigerator doesn't work
Replace the touch pad.
Posted on Nov 07, 2009
Ambari
  • 901 Answers
SOURCE: Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
Posted on May 19, 2010
burkcs
burkcs
SOURCE: Whirlpool Double oven control panel
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
Posted on Dec 24, 2012
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
After a power outage my maytag model MFI2569DEQ1 fridge display panel won't light up. Pushing any button lights up everything and 88888 across fridge and freezer temps...
Unplug it for a couple of minutes, Try again. It may have been hit with a surge. IF that is the case, you are looking at main control board and some money. Contact your homeowners insurance if a surge has damaged it.
Jul 31, 2017 | Maytag Refrigerators
I have a maytag dishwasher model mdbh985aws1that stopped working. The controls buttons on the left light up when pushed but the buttons on the right (including the start button) do not work. Any ideas on...
The CONTROL PANEL and/or ELECTRONIC CONTROL BOARD are broken. Unless you are good with a multimeter and wiring diagram just order both and send back the parts you don't use.
Aug 26, 2012 | Dishwashers
Have replaced the water filter - how do i reset/turn off the "change filter" light ?
Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
    I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
    Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
    Blinking lights, unresponsive
    I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
    May 08, 2009 | Dishwashers
    No power to the water dispensor or other buttons on the door
    it has to be one of many things the Control Board or Double Outlet Water Valve,Dispenser Door Solenoid
    Here to help
    Shaun
    Nov 16, 2008 | GE GSS25JEMWW Side by Side
    Refrigerators Logo
    1,529 people viewed this question
    Top Maytag Refrigerators Experts
    Marvin
    Marvin
    Michael Thomas
    Michael Thomas
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
