Question about Necchi Sewing Machines
How do I insert bobbin in Necchi 200 ? - Necchi Sewing Machines
Posted by Anne Morton on
R.A. Ellis
  • Necchi Master
  • 12,731 Answers
Posted on Apr 05, 2018
Sagar
    New Friend:
I think it is easy
Students are you ready to know completely about the <a rel='nofollow' href="https://www.gsebsscresults2018.net/">GSEB SSC result 2018</a> of of the academic session 2017-18?? Then, you must continue to read this article as we have given all the updates of GSEB SSC Result 2018 at one place which you can't find it anywhere online
GSEB SSC Result 2018 Gujarat Board 10th Class Results
Posted on Apr 04, 2018
5 Related Answers
Anonymous
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
Anonymous
  • 47 Answers
SOURCE: necchi sewing machine
www.ifixmachines.com has lots of parts fitted to your sewing machine for a cheaper price
Posted on Jul 23, 2009
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Posted on Nov 20, 2009
SOURCE: i have a necchi sewing
if you have a snap in sewing table remove it first
at the bottom in front of the needle plate area is a bobbin case door
when you open it there is the bobbin case & also should be the feed dogs
always keep the bobbin area clean of lint or loose threads
take note of how the bobbin case is inserted in the bobbin area,, see where the thread tail is at on the bobbin case
then make sure the bobbin is wound correctly or it can cause sewing problems
reinsert the bobbin into the bobbin case the same way it's removed
I also have a necchi sewing machine, the base of your is like the base of mine, if you need a picture of inserting the bobbin,, send me a comment with your email address & I will send you a picture of the threading the bobbin case & inserting it
Posted on Nov 17, 2010
SOURCE: How do i thread an old Necchi 539 sewing machine, and insert the bobbin?
try youtube for a video
or these sites for a manual
sewingpartsonline.com
ebay
sewusa.com
sew4less.com
a1sewingmachines.com
Posted on Apr 17, 2012
Necchi sewing maching adjustments
try a new needle
rethread the machine top and bobbin
try adjusting the top thread tension
make sure the bobbin is inserted into the bobbin case correctly
Mar 23, 2015 | Necchi Sewing Machines
ebay
sewusa.com
sew4less.com
Apr 17, 2012 | Necchi Sewing Machines
My bobbin thread on My Necchi 681c keeps on jumping out of the slot, how can I stop this?
there are several possibility's
1.is the bobbin warped
2.is the bobbin case damaged
3.is the bobbin the right one for the machine
4.is the bobbin wound correctly & inserted correctly into the machine
Mar 26, 2012 | Necchi Sewing Machines
I have a necchi sewing machine. How and where do you insert the bobbin in model 525fa
Nov 17, 2010 | Necchi 3101 Mechanical Sewing Machine
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Why does the thread keep breaking ?
The most common reason is the needle not inserted correctly (backwards), other causes can be burrs on the needle plate opening or burrs on the parts in the bobbin area.
Jun 02, 2010 | Necchi 6011
Threading the bobbin- Necchi 535FA
Hi - I have a 510 Necchi sewing machine - how do a fill the bobbin?
May 04, 2010 | Necchi Sewing Machines
Problem inserting bobbin
Inserting bobbin into the bobbin case or problem inserting bobbin case into the shuttle?
Make sure the thread will feed from the bobbin clockwise and through the guide on the bobbin case.
Lift the lever on the bobbin case to hold the bobbin in place as you inset the bobbin case into the shuttle.
If the bobbin case for this machine as a "finger", this has to align with the opening in the shuttle.
If you cannot readily see this - move the bobbin case a bit to the left and right until it clicks into place.
Feb 20, 2010 | Necchi 6018 Mechanical Sewing Machine
Bobbin case on my 524fb necchi has come apart
Dwayne
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
85 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
