Question about Ricoh Office Equipment & Supplies
How do I reset the ink collector on ricoh sg2100n
Posted by henry on
1 Related Answer
Kandi Cook
  • 823 Answers
SOURCE: What do I do when
You need to contact the manufacturer to purchase another ink collection tank and replace it. I am not sure if they will give you instructions on how to remove and replace it yourself, but its worth a shot. Depending on the price of the tank, it may be cheaper to buy another printer?
Posted on May 14, 2011
Testimonial: "Thank you I will check that out"
I need ink collector for Ricoh S/N is MP CW 2200 SP
If you are talking about the "Toner Collection Bottle", this can be removed and emptied out. Once you re-install the bottle and close the door the machine will reset and normal operation can continue.
Mar 08, 2016 | Ricoh Office Equipment & Supplies
Reset wate tank ricoh sg2100n
hi there i have a solution for resetting the wast ink tank you don't need to buy a new tank every time.
1) carefully pry off the top of the tank
2) clean the pads from all the ink
3) hold the up and down keys on the printer while on for about 5 seconds then release and quickly hit the hash key.
this should bring up the service menu
4) move up or down until you see engine maintenance and hit hash
5) enter following code 3008003 the hit hash then hit exec with hash and ok
6) hit the back arrow to the previous screen with the code then hit the down arrow it should now read 3008004
7) repeat step 6
8) hit the back key until you see engine maintenance again the hit down and select end.
now turn off your printer then turn it back on again and your wast tank should now show as empty.
May 19, 2014 | Office Equipment & Supplies
How do i reset the counter when i have replaced a ink collector unit on my richo gx7000.
Push the menu key.
Push enter key three times.
Turn printer off then on
See my video at www.condetv.com
Search for waste ink.
Mar 13, 2011 | Ricoh Aficio GX3050 GelSprinter
GX5050N. Printer turns on. Then 5 seconds later, green light flashes and printer turns off.
I am trying to solve this problem right now. Ricoh says it is mostlikely a short in the print head which unfortunately means trash the printer. If your printer has a full ink collector you can reset it. go to www.conde.com and look at tech tips it is very simple.
Sep 06, 2010 | Ricoh Aficio GX3050 GelSprinter
I need to reset the cartridge chip gx3000
how to reset the chip in ricoh gx3000colour printer
Jun 16, 2010 | Ricoh Aficio GX3050 GelSprinter
I get a message that says ink collector almost full. I cleaned it and i replace it. But i got always the message :"inkcollector is not set. replace inkcollector". What have to do ?
After you replace the ink collector there is a counter you have to reset it to tell the printer that you are inserting a new collector
Jun 09, 2009 | Ricoh Aficio GX3050 GelSprinter
My ricoh 305on is displaying error 990. I have
change the ink collector located in the rear of the machine
Mar 11, 2009 | Ricoh Aficio GX3050 GelSprinter
Ink collector almost full
100% agreed with rrrdddrrrddd. In addition:
Go to Menu->System->INK CU Replace. You will get a warning that overflow may occur(and it's really a messy job), reset the counter and everything should be OK.
Oct 06, 2008 | Ricoh Aficio GX3050 GelSprinter
1,190 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
