I have a 2005 Dodge Durango with the infinity 6 changer CD player ' every time i push in a CD it comes right back out with even attempting to play. can you tell me what this problem is . im afraid to disconnect the battery to reset it, because i have heard that may cause even more problems because the system have a code you have to re enter and i don't know the code
These guys are offering a LOT of help!
Dodge Car Stereo Repair Removal Replacement and Installation
You MAY find your reset info there?
Anthony
SOURCE: 6 disc changer will not eject cds==
I had the same problem for months. I checked the owners manual, checked the fuse box, everything I could think of. Then, today, I did some online research and someone said one of the CD's is probably just jammed or slipped out a bit. The suggestion was to gently slide a credit card over the disk (through the door/slot, which in my case was partially open). I just tried it. The door closed and the message said "initializing". It worked! The CD player is back to normal.
SOURCE: I have a CD STUCK in my 2004 dodge Durango. How
1st try to hit the eject button multiple times in a row. If this doesn't work you have 3 options.
1= pull the radio unit, disassemble case, gingerly remove CD, and reassemble.
2=Go to dealer or repair shop and have them remove. If you have a warranty left, mopar should be able to help. Factory radios have been a problem with Mopar for years.
3= Go buy a new CD and forget about it
SOURCE: cd player quit working after i changed the battery radio still works fine.
kzingraff, I have a similar situation to Craig Waldie. I have a 2005 Durango and the CD player has not worked since I replaced the battery. Just like his 2004, the radio works perfectly, just not able to use the CD player. How can this issue be fixed?
SOURCE: 2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
SOURCE: need radio 'code' for 2000 montero sport with factory cd player
From Mitsubishi's site FAQ's
I need a radio code for my vehicle. How do I get this?
You will need to speak to your Dealer who can organise this on your behalf. You will be required to submit your details and proof of ownership.
By law FixYa can not provide this information.
