Question about Kenmore Kitchen Ranges
SOURCE: Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Posted on Jul 15, 2008
SOURCE: Kenmore Gas Oven F10
check the temperature sensor. TURN POWER OFF!If you open the panel where the controls are located you will see a connector that has about 10 wires on it. 2 of these wires will be violet. Pull off the connector and check the resistance between the 2 violet wires. It should be around 1000 Ohms.
If not, it is bad. part# for the Kenmore Model 790 is 316217001 - cost is about $25.00
Posted on Nov 14, 2008
SOURCE: self cleaning oven directions
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. Good luck, ya'll!
Posted on Dec 09, 2008
SOURCE: Need electric probe (plug/heat control thing) for...
I bought a used heat control probe/plug (Model 100) on E-Bay for $25.00.
Posted on Dec 27, 2008
SOURCE: My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Posted on Sep 21, 2009
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Nov 09, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Nov 22, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Oct 03, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Sep 01, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Apr 05, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Mar 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Jan 02, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Dec 17, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
59 people viewed this question
I searched usinghttp://www.google.com and did not find part numbers.
I did see this link, however, that might be of some use in repairing it.
https://www.the-quarrymen.com/q10464380_...
