Question about Firearms
Want to put a scope on a 995that I just purchased. There doesn't appear to be drilled hole for base. Whats is process to attach rail for scope and which product fits?
Posted by Guy Raymond on
How to aim on a shotgun for still targets at 20 yard with shot 4 steel shot
What is the type of choke you are using? You want a FULL choke for the tightest pattern. Then you need to "pattern" your shotgun. Put a large piece of cardboard (4' x 4') on a range backstop at 20 yards and place a highly visible 3 inch orange dot or simply draw a 3 inch letter x in the middle of the cardboard. Take a string, 36 inches long and staple it to the center of the dot or X then tie a pencil on the other end. Stretch the string out and draw a perfect circle on the cardboard 36 inches from the center, then remove the string and pencil. From a shooting bench, use a shooting rest to steady your aim. Shoot at the center dot or X by pointing the shotguns bead sight directly at the dot or x
Look at the pattern of holes the shot pellets made. If they are mostly centered within the 36 inch circle, your hold would be right on the target. If they would, say, be up from center, the hold would be below the target. Up and to the right, the hold would be down and to the left, etc.
A gunsmith can correct this and make the gun shoot so that your hold would be on the target instead of trying to compensate for the barrel characteristics of your shotgun.
Sep 13, 2018 | Firearms
What are the most expensive rifle scopes?
Nightforce, Leupold and Schmidt-Bender Scope will get up there in the price point. Schmidt-Bender glass especially will be quite expensive. Their high end glass can easily exceed $10,000.
Jun 04, 2018 | Firearms
Do I need fully multi coated Spotting scope or Rifle scope?
Scopes with fully multi-coated internal glass-to-air surfaces (lenses) are recommended as they allow the highest level of light transmission through the binoculars (90 - 95% of the light that enters the binoculars will reach the eye) with limited internal light scattering and reflectivity. This results in fully multi-coated binoculars, spotting scopes and rifle scopes producing brighter, sharper and higher contrast images than coated or multi-coated binoculars. Unfortunately, fully multi-coated optics are more expensive to manufacture and are often only incorporated into higher-end binoculars, so your choice may depend on budget.
Mar 22, 2018 | Firearms
Which is the best spotting scope under $ 250?
Bushnell Trophy Xtreme Spotting Scope
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Mar 17, 2018 | Firearms
HOW TO MOUNT SCOPE
Hello, Malcolm -
There are quite a few web pages with instructions on how to mount a scope on a rifle.
This web page may prove instructive:
https://www.shootingillustrated.com/articles/2017/3/22/the-right-way-to-mount-a-scope/
This is a link to a YouTube video demonstrating the mounting of a scope:
https://www.youtube.com/watch?v=8rFOtmWqBUI
You can find more web pages and videos with instructions on how to mount a scope by using your favorite search engine (Google, Bing, Duck Duck Go, Yahoo, etc.) and entering the following search phrase, with quotation marks as shown:
"mounting a scope"
Best wishes.
Mar 09, 2018 | Firearms
Where can I find base pads about 3/8" thick for a S&W model 41 magazine?
I was unable to locate a replacement base for the magazine, but used to when mag wells were added to 1911s, we would glue a piece of hard rubber or plastic to the base. You may have to shape it to match up. Easy fix if you have the materials.
Apr 07, 2017 | Firearms
Firearms Logo
158 people viewed this question
Top Firearms Experts
Marvin
Marvin
jws1013
john h
Are you a Firearm Expert? Answer questions, earn points and help others
