SOURCE: 55 cup farberware coffee urn.
A burn out element it means the two ends with the ohm meter should read infinity number or nothing depents from ohm meter in any case you should read that the two ends are open circuit somewhere the internal wire is cut off. As for the thermostat you should conect the two points where the lement is conected and turn the thermostat if you seen at onhmeter that aroud room temperature the themostat open and then if you rotate it reverse just litle bit and the theremostat close then the thermostat works fine. Youcan even here and small click when it open and close during the turning left and then right at the point of room temeperature.
Good luck.
Remember top vote for this answer
SOURCE: Need instructions for use of Farberware 55 cup Coffee Urn
Hi 2 scoops of coffee to 3 cups not mugs. Then take it from there, adjust to your liking. Ron
SOURCE: Need pump tube for 55 cup farberware coffee urn.
Hi. Go to repairshack.con. Good luck. bobbyone
SOURCE: directions for 55 cup Farberware urn
Hi, you use 3 scoops of coffee for 4 cups. Then go to what you like. bobbyone
