Question about Necchi Sewing Machines
I recently purchased a necchi automatic supernova ultra sewing machine. I was unable to get any power to it. We used a power locator and found that the power stopped at the motor. Any suggestions?
Posted by Connie Murray on
Tom Chichester
    Top Expert:
  • Necchi Master
  • 56,001 Answers
Perhaps the motor has failed.
Posted on Apr 04, 2018
5 Related Answers
yeroc
Custom Exchange
  • 397 Answers
SOURCE: I have a Necchi supernova Julia 534
sounds to me like a tension issue, also are you using rayon or polyester thread, this is just a recommendation for those types of threads,,,,,,but please check your tension, is it only doing it during automatic
Posted on Jan 21, 2008
Anonymous
SOURCE: Necchi automatic BU supernova sewing machine
Hello! Hello!
Your machine is probably not 50 years old. I have one just like it that we purchased about 5 years ago. Necchi makes a very sturdy reliable machine. There are a couple of tricks, though. First, your bobbin thread has to turn clockwise. If it doesn't, it will either not sew, the stitch will look horrible or the thread will break. Second, threading it is pretty easy; however, I can't explain some of the parts. I would be happy to scan the diagram and e-mail it to you. E-mail: [email protected]. The tension should be set at 3 unless you are doing a ruffle or close zigzagging (machine applique). For applique, I find that I have to move it to 2. For ruffles or gathering, set it at 0 and your stitch width to 4. Another trick is to hold the top thread for the first 2 stitches. This alleviates a bobbin catch at the beginning. Other things you will want to know are in regard to the two knobs. One is pretty simple. It has a line that gradually increases in a zigzag. This knob basically adjusts the width of the zig zag. Obviously, for straight stitching, you would make sure the straight line is towards the top. The other knob determines the type of stitch you want to do. The red stitch options on top of the machine can be done with #1, 2, 3, 4 or 5 at the top; however, I usually use #1. The blue stitches are really fun! Simply decide which stich you want and make sure the corresponding number on the dial is turned towards the top. Also, it is very important that you adjust the other knob to the largest zigzag possible AND change the stitch length to 4. Don't pull on the fabric from behind the machine as you are sewing, because the machine will go forward and backwards while making many of these stitches. The green A, B, C on the dial are used for the automatic buttonhole feature. In order to use this, make sure you have the button hole foot. It looks like a long rectangular piece of plastic with measurements on it and hollow in the center. Not sure if that description makes sense. Anyway, the first step is "C." Make sure you begin with the button hole pressure foot measuring "0". Also, change your zigzag width to the desired width AND change the stitch length to less than 1. (You will notice that this area has a green line on it.) Begin stitching. You should be moving forward. When you have reached the desired length, make sure the needle is up, then turn the knob to "B" (sometimes I make my zigzag wider for this part), begin sewing. You should not go forward or backward. This step makes the bottom of the button hole. I only make 3 or 4 "B" stitches. When done, make sure the needle is up, adjust your zigzag back again if you changed it for B, and set it on "A". This will take you backwards. If you started your button hole with the foot on 0, it will automatically stop moving backwards when you reach 0 again. At this point make sure your needle is up again, then set the knob on "B" once more. If you adjusted B before, do it again. There you are! You can use twin needles on this machine. It also works well with a walking foot for quilting. Oh! To wind your bobbin (starting from the thread spool) you need to slide the thread under the little metal knob sticking out on top of the metal "?" right above the tension and then insert it into the hole in the bobbin spool. Push the bobbin to the right. This locks it into place. Next, hold the outer part of the flywheel (round wheel on right side of machine) while turning the inner wheel towards you. This will disengage the needle and allow the bobbin to wind. Now you can press on the "gas" and wa-laah. It will slow down and almost stop when it is completed. Cut your thread, slide the bobbin to the left to unlock, tighten the wheel and you're done. If you have any more questions, let me know. Hope this helps!
Posted on Oct 18, 2008
Anonymous
  • 8 Answers
SOURCE: Need belt for necchi supernova automatica sewing
You can also use a Eureka vacuum cleaner belt, can't remember the exact model, but the package says it's for most sewing machines. It's not the V belt, but it works on my Super Nova and it's 1.79 for two!
Posted on Oct 11, 2009
Anonymous
SOURCE: VALUE OF NECCHI AUTOMATIC SUPERNOVA ULTRA MARK 2IN
in Italy I have bought it by 25 euro :) - yesterday ;)
[email protected]
Posted on Feb 28, 2010
Anonymous
SOURCE: Where to put the oil for a Necchi Lydia 3 sewing machine
Beldia 1306 - did you ever solve your sewing m/c problem. I have just resurrected my old Necchi and have the same problem, power but very sluggish operation of the needle, could be oil that is needed. Can you help?
Posted on Dec 08, 2010
I changed the light bulb in necchi automatic supernova ultra mark 2 and still no light
In that case, I would assume a 'short' in the wiring. Which you could find with a current tester. Hubby has one, not that he has taught me how to use it. Or - My industrial machine has no light, so I've picked up a nifty folding lamp with ? - a light source that provides solar light spectrum. Check at thrift stores, or at any Wal-Mart. Not all that pricey, now.
Feb 08, 2018 | Necchi Sewing Machines
Who manufactures the ultra dressmaker free arm sewing machine?
NO idea look on the machine for a name like SINGER
Jan 09, 2016 | Sewing Machines
Necchi supernova manual
Most sewing machines can use a double needle, the one with the single mounting shank and it turns into two needles.
MAKE sure you have Zig Zag needle plate installed to accomodate the double needle.
Turn hand wheel slowly to test then use thread and fabric and turn flywheel by hand to test sew.
Jul 19, 2014 | Necchi Sewing Machines
My mom has a Necchi supernova ultra that needs a new belt. What is the correct size and where do I find one?
Just measure the existing belt and go from there. Besides the supernova and supernova ultra are likely to use the same belt.
Sep 07, 2012 | Necchi Sewing Machines
Stitch length control knob broken on my Necchi Supernova Julia
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
Apr 24, 2009 | Necchi 4595 Mechanical Sewing Machine
Jan 21, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
66 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
