Medical Logo
abena ofosua Posted on Apr 03, 2018
Our schiller AT-102 Plus does not show trace on the screen as it does normally after the leads are connected. what could be the trouble?
marilburns
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 12, 2018
marilburns
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
793
Points
6
Buy Tadalista 5mg (Tadalafil) composed pills are very first choice of impotent men. This Tadalista 40 medicine has proven to be the best solution as a perfect weekend medicine for maximum bliss. The medication is available in conventional tablet form and is most powerful pill than other ED medicine. High powered pill contains 40mg of Tadalafil to keep men charged up for entire week end! Buy Tadalista 5 mg AllDayGeneric com My Online Generic Store
JoanWee
Level 1:
New Friend:
JoanWee
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
793
Points
6
Give Me 10 Minutes, I'll Give You The Truth About Buy Tadalista 40 mg Do not take more than one dose every 24 hours. It's cannot be taken at the same time as other medications used to treat male erectile dysfunction problems. Buy Tadalista 40 mg AllDayGeneric com My Online Generic Store
PerWebrer
Level 1:
New Friend:
  • Posted on Apr 11, 2018
PerWebrer
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
793
Points
6
Our company objective is to sell high quality medications only at affordable prices, and to satisfy as many customers as we can. That is why we offer lower prices compared to the other merchants. Buy Tadalista Professional Buy Tadalista Professional AllDayGeneric com My Online Generic Store
1 Related Answer
Anonymous
  • Posted on Mar 13, 2009
SOURCE: the window on our schiller AT 2 plus ekg machine is too dark
When you first turn on the machine, hit the up or down arrows to adjust the brightness of the LCD screen.
1helpful
Schiller at-1 says lead off
Check the leads. If any of the Leads is open the this problem can occur. You have to check the continuity of each cable for the lead end to socket. All leads should show a resistance of 10KOhm
If you wish to get some details About schiller AT1; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Do you have a poster for correct lead placement for AT-2 plus ECG? thanks!
hi,
If you need to know how to place the leads then whach the following video. All 12 channel ecg machines have the same lead placement
My AT-2 plus EKG suddenly stopped transmitting from the electrodes, i.e. all the leads show flat line. My e-mail is [email protected]
hi,
You have to check the patient cable of you machine first. you have to check the LF (left foot ) lead of the cable. if there is any other cable you can try it with that. if there is any other ecg machine you have which has the same connector. then try with that also. if the cable found faulty then replace it. Is there is any trace ( line trace ) in the paper for lead 1 to v 6 if not , the problem is with thermal printer of you machine. if so you have to contact the nearest schiller authorized service center. Because the thermal printer head is not available in the open market.
ok
3answers
High, I have a Schiller AT-2 light that is printing too lightly suddenly. Hard to read the lower page tracing in particular. Had it 5 years, doing well. Anything to adjust that?
hi,
Your machines thermal printing head have some problem. Thats why it give printouts very light. Not possible to repair thermal head. You have to replace it.
ok
Welsh allen at-2 lead light is on however ekg machine will not give tracing
hi,
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
ok
2answers
My schiller at 102 is not charging and shuts off every time i attempt to print. Any ideas on what might be the problem?
hi,
One of the cause for this problem is the faulty backup battery. normally ecg machines runs on battery even if the power is connected. The power supply of ecg machines is meant for charging purpose only and doesn't have that much power to run the machine. also the companies will not recommend to take ecg at mines on condition.
First of all check the charging voltage is there or not. The battery charging voltage is 13.8v . check is the voltage is there at the pins of battery ,in mains on condition. If its ok the the battery have to be replaced. Normally the battery will be faulty.
ok
1helpful
I Have a Schiller AT-102 ECG The problem is that the paper wanders out the paper sensor area and i get out of paper signal. The paper tray is 211 mm the paper size is 209 mm and no matter what i do the...
Hello!
I have the same model (Schiller AT-102) and unfortunately the same problem. I've tried almost everything with the hope of solving the problem: I changed the tightening springs which push the printer thermomatrix to the roller. Also replaced the optosensor. And so on... But nothing changed the situation. I would ask you to tell if you already have found the cause and the cure. Thank you in advance!
1helpful
2answers
Just ordered a schiller at1 ekg machine, just realized it is 3 channel, does it have a 1 channel mode where just one tracing will print?
hi,
u can make it single channel one by changing its setup. it will print single trace in the same paper. when u select this option it use more paper than the three trace.
ok
I just bought a unit AT2plus Schiller, and am having problems with the performance of the ECG. The ECG trace is getting too thick, making the visualization and interpretation. The change is seen in all...
There is a process for cleaning the print head. Try that first. I did a quick read of the manual, and it appears filters CAN be adjusted, but I would regard that as a last resort solution.
Also, adjust trace height (mm/mV) and paper speed to spread out the trace.
1helpful
2answers
The window on our schiller AT 2 plus ekg machine is too dark
Top Schiller Medical Experts
john h
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Schiller Medical Expert? Answer questions, earn points and help others
