SOURCE: key fob will not undo
If you don't have one that works for the vehicle now, you'll have to take it to your local dealer to have it programmed to the vehicle. Some will charge for this, some will do it at no charge.
If you do have a remote that is programmed and working for the vehicle, then the following steps will allow you to program another remote:
1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold the unlock button on the working key fob and hold for 4 seconds, then also press the panic button.
5. Release both buttons and you should hear a single chime to indicate it is in program mode. You have 30 seconds after the chime to program any additional remotes you want to program.
6. Press and release both the unlock and lock buttons simultaneously on the remote you are programming. You should hear another single chime.
7. Within 4 seconds after hearing the chime, press either lock or unlock button on remote that you are programming.
SOURCE: key fob keep on failing to work
sounds like you have a aftermarket system installed,this is most likely interfaced with the subaru keyless,this system needs to be removed to diagnose,i believe the aftermarket system is causing the concern,i've seen many problems arise with these components
SOURCE: cobra 7777 car alarm going off for no
kept waking neighbours took car to alarm specialist who disarmed it.
SOURCE: alarm went off and key fob quit working
start the car. if that dose not work remove ground form battery then after it stops put ground back on that will reset the alarm.
Testimonial: "started the car, shut it off and the alarm quit. But now none of the features work on my key fob."
SOURCE: how do you re-link the key fob to the car after
Try this,,turn the key on ,wait 10 minutes,then turn the key off,then right back on,do this three times,a total of 30 minutes,this should reset the key fob,if this is the problem.
