Cameras Logo
Question about Sony Cameras
How to fix sony digital camera that fell in water
In the the sea and is now not switching on
Posted by arun_madhavj on
5 Related Answers
Anonymous
  • 53 Answers
SOURCE: Fell in sea / wont turn on
would you like the bad news or worse news first? salt water begins to corrode almost instantly (bad news) time to buy someone a new cam (worse news) sorry
Posted on Jun 08, 2006
Anonymous
SOURCE: Sea Water problem
You'll need to buy another camera. If it had of been fresh water you could dry it out and MAYBE it would work, however, salt water shorts out the electronics. (salt conducts electricity, blah blah blah.)You could try putting it in fresh water since you can't make it any worse, then let it dry out and see what happens. In my experience, salt equals death.
Posted on Sep 11, 2007
Anonymous
  • 72 Answers
SOURCE: Camera is not getting on - after fell in sea water
Camera was dropped on a hard deck or into any water solution.
My Answer:
Whether your camera was dropped into any water (or onto a hard deck for that matter) - even for a split second - the damage has already been done. Esp with the "hard deck" drop.
Unless your digital camera is a totally "100% waterproof down to X number of feet" sports digital camera, or quite possibly a "water-resistant" sports digital camera I'm afraid you got water into the "lens barrel" area of the camera and that usually is just as FATAL as getting water into the camera anywhere else as well. Esp if it's SALTWATER!!
Saltwater will destroy any camera (or anything else electronics for that matter) just as bad as leaky batteries will. Once those micro circuit-boards get that acidic saltwater or batt acid on them it's only a matter of time before TOTAL FAILURE.
Sometimes it's immediate, and other times it takes awhile for that saltwater/acid to do it's damage inside. But it will happen - as I know very well from all my years of repairing electronic equipment no matter what it was - Marine environment stuff as well.
See - those saltwater crystals left behind never go away once the water evaporates. Only way to possibly get that saltwater out initially (out of anything electronic dropped in ocean water btw) - with any luck - is to first remove any and all batteries from the damaged electronic item(s).
Next - squirt ALCOHOL (91% or higher rubbing alcohol, or better yet 99% Isopropyl Alcohol) into the openings where you suspect the saltwater got into the camera (or other items) to begin with, and then hold the camera with the lens barrel facing down while shaking the excess Alcohol out. Just letting the excess ALCOHOL drain out by itself won't do, as you need to get out as much as possible thus carrying the saltwater by-chemicals out with it as well.
If you have a compressed air source - no higher then say 20-30 psi, or a LPHV (Low Pressure High Volume) regulated air pressure source - use it instead to forcefully blow out any and all Alcohol as best you can.
Next - take the flushed out camera and open up any access panels, memory card slots, battery port doors, display panels, etc and place the camera in a kitchen oven that uses GAS ONLY, and with ONLY the PILOT LIGHT burning leave the camera in there for no less then a complete week (7 days)! NO LESS then 7 days!
That low PILOT LIGHT ONLY heat temp ( < ~ 110-115F ) will never harm anything electronic (as I use mine all the time to naturally dry things out that have gotten wet for one reason or the other). It will thoroughly dry out the camera insides and hopefully remove all traces of moisture and salt residue! Hopefully!
If you keep using that camera without at least doing the above FIX with Alcohol - after you have exposed it to saltwater - then I'm afraid your camera will have suffered unrecoverable internal damage and will fail totally at some point thereafter.
Saltwater and Electronics DON'T MIX - plain and simple.
Same goes for any camera that has been dropped on the "hard deck".
The guidelines and consequences of a dropped camera are listed below as a general guideline of what NOT to do, what to do afterwords, and what to do to try and prevent a camera drop to begin with.
I'm afraid that "drop", or "small drop", or even that "very big" drop you - or anyone else here posting - spoke/speaks of was more like that of a camera ending life - as related to all digital cameras. No matter how much that ?-year old ???? camera cost when new.
Not all digital cameras are created equal, and if you are an active sports person, or something close to it whereas your camera is subject to or exposed to this kind of rough treatment then you might want to consider doing several things from now on.
Unfortunately it sounds like you dislodged the imagining converting pixel matrix chip and/or the related optical components that convert the optical picture information into digital information that is processed to the memory card for storage.
You may have even possibly dislodged some PC connectors (printed circuit board connectors) inside the camera. Not to mention pulsed servo motor drive components as well.
Each camera is different as to how many individual circuit boards they have inside. Could be 3-4-5 or more. Each is interfaced by a paper thin flat interface type cable and it's possible that particular board cable could be damaged as well. Hard to say. Very very complex inside!
I've had a few destroyed digital cameras apart myself (that people gave me to try and fix) - just to see how they were put together, as I knew they were toast right off the bat in less then 5 mins after looking at them. If it wasn't bad batteries leaking inside and destroying the many smaller circuit boards inside, then it was dislodged and broken parts inside from being dropped.
In any case - each digital camera I had apart WAS NOT worth repairing if taken into an authorized repair dealer or even the main factory repair outlet. Esp if it is/was a SONY!! Sony anything is really not worth the repair charges they want today. Totally ridiculous as they charge you roughly $35-50 today just to even look at whatever is broken of theirs. Then comes the actual repair cost on top of that. I won't buy anything of theirs anymore, as they burned me twice before years ago - and twice was enough....
Not so with Olympus and other digital camera makers! That is why all my cameras today are Olympus because of the GREAT factory warranty or out of warranty service I received past to present. They are the best in my books and I have NO TIES AT ALL to them in nay matter or form!
One thing I should mention here regarding digital cameras in general, as with all 35mm film cameras as well is this.
With digital cameras that cost less then $200 (esp those under $100), and those that are say 3 to 5 years old already - if they break internally for whatever reason (ie: batts leaking - worn out drive motors - dropped camera - water damage - etc) they are considered THROW AWAY CAMERAS and NOT WORTH FIXING. Plain and simple - all sentimental attachment aside btw. Always remove and keep the Memory Cards before throwing out any damaged "beyond repair" camera though. The cards can always (possibly?) be reused on your next digital camera purchase.
With any new camera purchase over $200 it's always an added decision whether to buy the 2 or 3 year EXTENDED WARRANTY - as related to the added cost. I know I would have, and I have done so on my $400+ higher ended Olympus 35mm film camera not only because Olympus builds the best and are renown for their lens QUALITY worldwide, but because I wanted the extra PEACE OF MIND knowing an act of God or Mother Nature could occur at any time. It just made sense to me at that time!
Continued below:
Posted on Aug 29, 2008
Anonymous
  • 13 Answers
SOURCE: my canon digital camera IXUS
sefesfsefesfsef
Posted on May 13, 2011
Anonymous
  • 32281 Answers
SOURCE: My Sony Camera fell in the sea water, can it still be fix? How?
Salt water damage is very bad for electronic devices, especially if the device was switched on at the time when it was dropped into salt water.
The cost of repair if you can get someone to repair it would most like be very expensive.
I would recommend you purchase a new camers, it most likely be a later and better model.
Posted on Dec 19, 2011
My camera fell into the water
What kind of water? If it is sea water it is probably gone as sea water is highly corrosive. Did you immediately remove the battery and leave it out? If not, then the water, which conducts electricity, could have sent over 300 volts from the flash circuit into the rest of the camera and fried a number of circuits. Without seeing the camera it is impossible for me to give any other suggestions
My camera fell in sea water
My sympathies. If you immediately fished the camera out, removed the battery, rinsed it in fresh water, and let it dry thoroughly before even thinking about putting the battery back in and seeing whether it turns on again, then you MIGHT be able to salvage the camera. Otherwise it's time for a new camera.
The pictures on your memory card should be okay. Just rinse the card in fresh water and let it dry before trying to read the card.
Sony camera sea water damage and wet
Highly unlikely that it can be repaired, salt water caused corrosion and will short out electronic components when the battery is connected.
I suggest you put your money towards a new camera.
Sony cybershot DS W80 is not switching since mother board is u/s. It fell in sea water. suspected problem in LCD also. spares are not available other than sony company servicing centres which is very...
The repair to any camera damaged by sea water will cost more than the cost of a new camera since everything must be replaced because salt water is corrosive. Add the replacement parts to the labor costs and you now have a repaired camera that cost more than a new one.
My camera fell into sea water but it is still under warrenty.... will they repair it for me?? its just 2 months i bought it..
No, they will not fix a problem caused by the owner dropping the camera in the ocean....only manufacturing defects.
Sony cybershot dsc-t77 fell in fresh water
Hello :
Please read this solution here . Please give the solution a try . It has worked with alot of mini devices just like your Camera .
good luck .
please don't forget to rate !
It fell in sea water puddle and now LCD screen won't work
If you tried turning it on before the water finally evaporated (a week or more), you might have shorted out the screen. Also, after the water evaporates, there is the problem of the salt residue left behind inside the camera. Get a repair estimate to help you decide if it's worth the repair.
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
