When I put on heavy duty heavy soil, deep fill.....even thou on deep fill it sill does the sensi fill puts a little water in and tries to adjitate which is going to break because adjitating dry clothes... the adjitator adjitates like it is washing delicates, also when I held the button in to get to unlock it wouldn't unlock so I had to unplug it to reset the computer so it would unlock..... please help
SOURCE: moffat washing machine older really older cant find model number
clothes need be more drye ofter end work
SOURCE: I have a Kenmore Elite washing machine-wont spin
remove the lower panel. it is held on with 3 1/4 inch headed screws. With a pail to catch the water, remove the clean out cover. Ifr the clean out is plugged, the washer will not drain.
SOURCE: adjitator won't work
if the adjitator and the spin cycles do not work the coupler between the motor and the transmission is at fault
SOURCE: top of washer adjitator turn loose of the base
Check these out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
