Question about Optics
Ps3 Snakebite wired controller, wont turn on
Camo Snakebite
Terry
  • Optics Master
  • 11,377 Answers
How do i program my ps3 bluetooth headset?
You can pair the headset in two ways:
  • Automatic mode (using the supplied USB cable) - Enables the headset's advanced features for the PS3. Using automatic mode, you can pair the headset with any PS3, but only the most recently paired PS3 will be saved in the headset's list of paired devices.
  • Bluetooth discovery mode - Sets up the headset as a standard Bluetooth headset. By using Bluetooth discovery mode you can pair the headset with many other Bluetooth devices.
Jul 22, 2014 | Subsonic PS3 Bluetooth Headset Camo
My core controller just vibrates
Hi
The problem may be with the game. some PS2 games are partially compatible with PS3.
When the controller vibrates and turns off use the wire to switch it on and keep running.
Jul 02, 2013 | Nyko Raven Motion Sensing Wireless...
I have a madcatz call of duty black ops controll, it charges when i connect it but wont connect to my ps3? help me!
You need to sync your controller with the ps3, put the USB dongle into one of the available slots on the ps3 - exactly where you would normally connect a wired controller on the front. Now switch on your ps3, the dongle will connect, now put your USB cable into the black ops controller and switch on - your 4 lights should be flashing on the controller. Now press connect on the USB dongle, your controller should now sync to the ps3 and hopefully will show as controller No 1. Remove the USB cable and play wireless.
Jul 13, 2012 | Mad Catz Call of Duty Black Ops...
I have a big ben ps3 controller, and when i push the ps button the red lights just flashing and then turns off, it just wont connect to my ps3.. please help!
Welcome to Fixya. Heres how you can connect your controller to your PS3.
1. Press the tiny Reset Button on the back of the controller
2. Plug in the USB Connection wire
3. Restart Console
4. When loaded, Press the PS Button
5. Disconnect the USB wire
Then it should have recognised the controller and auto-assigned, hope this works for you
Rate me if it works so that i can help other people like you!
Thanks for using Fixya
Feb 25, 2011 | Sony Wireless Controller for PS3
My ps3 controller wont work ive charged it up and it still wont turn on
You may have to get another ps3 controller the battery in the inside might have smashed because of throwing it on the ground or just breaking it.
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
Controllers will not connect to playstation console.
connect controller to ps3 using the chragin wire then lick the ps button on the controler
if nothing happens turn on ps3 manually with the controller still connected and it should recognise it again
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
My ps3 controller wont turn on
the battery might be dead if its wired its probably a loose cord in the wire
Aug 22, 2009 | Sony Playstation 3 (PS3) Console
Mad catz gamepad for ps3 wont work..help
On Most Models They Will Work When You Hit The Reset Button On The Bottom Of The Receiver.
Feb 04, 2009 | Mad Catz PS3 WIRED GAMEPAD
My ps3 controller wont connect with my ps3
Brian,
If after connecting to the USB it still won't work wireless, the best thing to do is this:
1 - Connect the controller to the PS3, via USB
2 - Click the PS Button to turn on the system
3 - On the XMB screen, click the PS Button again. You'll get the options, to "Turn off the controller". Do that and then turn it on again. It will reconnect with your PS3.
Regards,
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Optics Logo
429 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
