Question about Dewalt Tools & Hardware - Others
I borrowed a dewalt 15 gage angled 34 degree only finished nailer. I bought a box of dewalt 15 gage FN style angled finish nails, they keep jamming. Model D51275. The nail angle looks <34 degrees.
Posted by Ron Alberts on
Simon Flummox
    Novelist:
  • 91 Answers
As you may have suspected, FN style nails are the wrong angle (approx. 25 degrees) for your tool, which needs the DA 34-degree nails.
Here's a webpage with a brief description of the two styles-
DA vs FN finish nails Fine Homebuilding
In case you (or others) need it, Dewalt's ServiceNet does have the D51275 Instruction Manual available for download-
Detail
Note that there were three Types/generations of this model, so you have to choose the correct Type before you can get to the manual.
Posted on Apr 02, 2018
Al Schrader
    Master:
  • 438 Answers
If previous nails worked, they sold you the wrong nails.
3 Related Answers
John Trevino
  • 1420 Answers
SOURCE: what brands of nails will work in my 15ga finish nailer 1000993
Here are a few tips on buying nails for your nailer. Nails are sold in two basic categories, clip head and full round head. The clip head are lower in price and are usually taped on glued together with no spacing between them. The full round head have spacing between each nail and are held together with plastic. Some nailguns can use both types. It is important to verify the angle of your gun. To measure the exact angle use a straitedge along length of rails and a protractor at the barrel of the gun. Place the protractor on the barrel with the 90 and 0 degrees aligned with the barrel and hold the straitedge aligned with the rails and the 0 degree mark. Read the angle. You may find that your gun measures a different angle. Nails are sold from 0 to 34 degree. 34 degree is usually clip head for Paslode, Senco, Hitachi and other brands. I find that many brands of nails do not list the angle, but list the name of the gun instead. This makes it difficult for non-branded guns. Take the protractor into the store and measure the angle of the nails or place the nails on the outside of the rails to see if they align with the barrel. Shop several stores because nails vary by brand. Once you verify the perfect fit, ask for a sample strip to try in your gun. When you identify the angle and type, use this information to shop for price. Most nails are imported from around the world, however there are nails still produced in the US costing more. Home Depot and Lowes do not carry a full range of nails.
=Google the internet for more info on nails such as www.nailzone.com. They sell a 33 degree nail that may fit your gun. Good luck and email me or post again with more questions.
w
Posted on Jan 19, 2009
Thomas F. Schneider
  • 2715 Answers
SOURCE: Need nails
Do a search on Google or Yahoo to find sellors and prices.
Posted on Mar 23, 2009
Kris
  • 38 Answers
SOURCE: Just got a freeman 15 gauge 34 degree angle finish nailer.. won't fire. Already put oil, Check just in case if there was something jammed but nothing..
Does it get enough air pressure to push the nail out ?
Posted on Feb 21, 2015
Why is my DeWalt D51275 15 gauge angled finish nailer bending nails and jamming?
A few things to check - some may seem overly obvious but humor me:
1) Check your nails - make sure they are the correct angle and gauge
2) Check to make sure there is not a piece of a broken nail in the nose
3) Check the driver blade & insure it is not bent or chipped
4) Make sure the nail carrier spring is pushing nails forward and isn't getting hung up
Jun 08, 2014 | Dewalt DC628K Factory Reconditioned Heavy...
Will not fire
Nail strip may not be fully seated, the ram may not have retracted due to no lube, or dirt or damage to an O-ring, or the saftey may not be disengaging, such as due to a bent lever, or faulty seals.
Dec 17, 2012 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
Looking for a dewalt1276 manual for a 34 degree 15ga nail gun
There are a couple of videos at youtube
Look for: dewalt d51276 nail gun instructions
Mar 19, 2012 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
What angle (25, 35, etc) collated nails should i purchase for this tool
Info on your gun can be found here:
http://www.toolbarn.com/bosch-fna250-15.html
It uses 34 degree nails that I have seen available at Lowes. Good holiday
Dec 31, 2010 | Bosch Fna25015 15 Ga Angled Finish Nailer...
Nails keep jamming in the gun. how do you fix that and not sure about the correct air pressure.
Not all nails are exactly to gauge, but if they measure about right (take one nail off strip and see if it fits snuggly into bottom of nose) most likely the problem is the driver; missing tip or bent. Remove head and pull out driver. If just the tip is broken you can grind it square again and if bent you could try to adjust. If not driver is available at dewalt service center and at www.toolpartsdirect.com Good luck
Oct 09, 2010 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
Will the nt65ma3 use fn style finish nails
(fn) stands for finish nail,,, and there are different types of those,, this hitachi will use 15 guage, angle finish nails,, do not attempt to put 16 gauage strait or 16 guage angle nails in this gun,
Dec 04, 2009 | Hitachi NT65MA3 2 1/2 Inch 15 Gauge Finish...
Nails don't go all the way through?
A couple of things, first i would just suggest checking all the orings and gaskets to make sure air isnt leaking, and second make sure the intake fitting is properply set. I believe an air leak is causing this to happen.
Nov 06, 2009 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
Need nails
Mar 23, 2009 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
Tools & Hardware - Others Logo
175 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
efs_perpends
efs_perpends
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
