I dont know how to get the internet on my vizio tv.
I am assuming you have a smart TV. If not, the best you can do is have the TV act as a monitor for your computer. If it is a smart TV, it must be connected to the internet by one of two ways. 1. wireless: Most smart TVs have Wi-Fi built in. In order for this to work, you need to have a Wi-Fi system in your home. Your TV manual should walk you through the steps to connect to your in house network. This will be different depending on if it is secured or unsecured. 2. Hardwired: If you have a hardwired internet setup, you need to run a Category 7 (Ethernet) cable from your modem/router to the Lan connector on your set. It is the one with the symbol of a horizontal line with one box centered above the line and two boxes below the line. In either case, if you want to use the browser function, you must attach a keyboard to the USB port on the set. If you do not have a smart TV you can connect the TV to your computer using an HDMI cable. It will then act as a computer monitor when the TV input is set to that HDMI input. I hope this helps.
