Try the HP/Samsung site since HP bought out Samsung printers and copies
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Will not upgrade to latest firmware
The newest firmware version is actually v 2.01.
The file should be called DI634M_firmware_201.bin and is engineered for North American products only. Does that apply to you?
You can get the file here.
Important! - Make sure that you use only hard-wired network connections for upgrading. Do NOT upgrade firmware on any router over a wireless connection. This might result in a device failure.
Here is also a page with detailed instructions.
If you have any more questions or this doesn't work for you, just come back here and leave a comment - I'm happy to help.
SOURCE: Reverse Firmware Upgrade
http://www.fixyourownprinter.com/forums/printer/56368
There are two different print engines used in the CLP-300. One for
2006, and a different one starting in 2007. I have the older 2006
printer, and the current firmware is only for the new 2007+ print
engine.
I talked to Samsung support here in Korea and fixed the
problem. They sent me to their special tech support website at
www.1479.co.kr (only in Korean) and I was able to download an older
version of the firmware which restored my printing ability.
The latest version of firmware that worked with my printer was found in this post: http://www.bassmania.co.kr
Download
the two files at the top, then extract the archive. Drag-n-drop the
correct firmware file onto "usblist2.exe" and the printer will be
flashed with the firmware (must be connected via USB if you're using
the CLP-300N model).
SOURCE: Samsung yp-p3 firmware upgrade
Place the bin just inside the P3(not in any of the folders) and then disconnect from the computer and power it back on. It will check the firmware and turn on and off a time or two. When it's off and doesn't turn back on power it back on yourself and you're done.
You can check your FW version by going to settings>about on your P3.
SOURCE: tried to download firmware then
hello, i figure you folled the instructions regarding the up grade. if upgrade did not work, try using usb, if still not working, problem will not reset, and just like the old computer main boards with cmos upgrades, if did not work then main pcb will need to be replaced.
SOURCE: Samsung CLP-300N I stupidly upgraded the
Hi
There are several firmware versions available on the Internet. Rather than playing with firmware that it is not coming from Manufacturer, you should contact the local Samsung support and get the previous firmware version from manufacturer.
Use the contact links in Samsung page, they will address you to a downgrade for the printer. Use either phone (if you are US based) or chat links at the right hand side of this page.
