Question about Dewalt Tools & Hardware - Others
Changed blades on 733 dewalt planer now rollers not working could it be associated chews up broards
Posted by Sandra Beatty on
Parson's Repair Shop
    Sergeant:
  • 237 Answers
Either the blades are incorrectly installed causing the head to jam or the safety cover is not installed properly - there is a safety mechanism that locks the cutter head when the cover is removed.
Posted on Feb 02, 2019
5 Related Answers
johnychel
isaac johny
  • 796 Answers
SOURCE: Changing blades on a Dewalt Dw733 planer ,need instructions
click here
this might help you
Posted on Jun 25, 2008
Anonymous
  • 88 Answers
SOURCE: Help i need to change my Dewalt DW733 Planer Blades i lost manual
try dewaltservicenet.com They have manuals as well as parts breakdowns.
Posted on Apr 16, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: need manual for dewalt 733 planer
Go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number DW733 on the next page click on the type you have under instruction manual. Type 1 I know for sure will come up, I have looked at it a couple times. The manual is 30 pages long. If I have helped would you please rate the information accordingly and Thank you
Posted on Apr 18, 2009
Anonymous
  • 7 Answers
SOURCE: planer is not feeding wood through without manual force
I had the same problem...sometimes you have to take the smallest amount off (1/64th) and it might work, otherwise your blades are probably dull. Try to feed the boards through the planer towards the sides, not just the center so they wear evenly across the length of the blades. They wear out very quickly, which makes this planer very frustrating. If you take the top cover off and inspect them, you'll probably see nicks in them and it's time to replace or rotate them. Each blade has two sides you can remove all the screws using the T-handle wrench from the top cover and flip them. Also, as the blades begin to wear, the planer will become louder and louder. That's another way to tell. When you install new blades notice how much quieter it is when you plane boards.
Posted on Aug 29, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: How to change Blades on Dewalt DW 733 Planer
Go to Dewaltservicenet.com and in the middle of the page towards the bottom is a box indicating manuals/breakdowns. Type in your model number and you can download one this way.
Posted on Jul 21, 2010
How do I download dewalt 733 manual?
Try Googling (DeWalt)(733)(manual) without parens.
Apr 27, 2017 | Dewalt Drills
Dewalt 735 planer trips overload a lot. New blades, thin cut no difference. Run it, without wood, it trips. Overload switch? Checked everthing. Turns free with chains off. Bluespook
id check the feed roller drive or feed rollers them selfs I find due to pressure there under most times they get flat spots in them from sitting makes for a hard start to planer
its best to back off tension rollers when storing these and keep them bearings lubed up well
and yes it happens to sealed bearings too
Apr 28, 2015 | Garden
Change the belt on a dewalt 733 planer
Here is a link to a site I am a member of, Lumberjocks.com. The link is for a discussion on how to replaced the belt on your planer!
Good Luck!
http://lumberjocks.com/topics/10176
Oct 03, 2013 | Dewalt Planer (DW734)
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
How to change Blades on Dewalt DW 733 Planer I lost the manual
Jul 20, 2010 | Dewalt Planer (DW734)
Apr 16, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Need manual for dewalt 733 planer
Apr 10, 2009 | Dewalt Tools & Hardware - Others
Planer is not feeding wood through without manual force
Nov 13, 2008 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Tools & Hardware - Others Logo
305 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
efs_perpends
efs_perpends
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
