I tried 2 times turning the breaker off for a few minutes, no change, I tried holding down the Energy Saver button and the Alarm Light together for 10 seconds and still flashing Pc Er Any advise would be appreciated
Https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/51---REZTUzlWS0JBU1M=/Refrigerator-not-cooling. i could not resolve the pc er issue however this web site may be of some use.
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
SOURCE: garage door opener will not go down.
After reading the responses I went out and looked at the sensors, but this time instead of aligning up and down I moved the one sideways and WOOHOO! the remote works fine now.
SherAng
Hi
With the doors fully opened, lift up the base grill. Tilt the top of the base grill away from the refrigerator. Set the base grill aside. Attach the 1/2-inch socket to the ratchet. Inspect the arrangement of the bolts located in the area where you removed the base grill. The bolts located to the inside of the door hinges are the leveling bolts. The top bolts adjust the back of the refrigerator, and the bottom bolts adjust the refrigerator's front edge. Adjust the leveling bolts as necessary with the 1/2-inch socket attached to the ratchet. Turn the bolts clockwise to raise the corner or counter-clockwise to lower the corner. If you notice the head of the leveling bolt pushing away from the face of the refrigerator as you loosen the bolt, re-tighten the bolt until the head pulls back flush. Switch to the other corresponding bolt to adjust the level of that side of the refrigerator.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
