Question about Kenmore Dryers
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
SOURCE: f2 error code
F-02 error relates to a malfunctioning user interface board, most commonly a stuck button.
Here's a link to the technical sheet for it which includes some tests you can run to determine the problem:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10035270.pdf
Posted on Jan 05, 2010
SOURCE: kenmore elite oasis dryer model #110.6708 will not operate
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Posted on Mar 19, 2010
SOURCE: need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 03, 2014 | Kenmore Oasis HT 4.7 cu. ft. Top-Load...
Jun 28, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Jan 01, 2018 | Kenmore Elite Oasis 6808 Electric Dryer
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Sep 24, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
Sep 10, 2011 | Kenmore 67032 Dryer
May 10, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Jun 22, 2009 | Kenmore Elite Oasis ST 7806 Dryer
Jan 20, 2021 | Kenmore Dryers
105 people viewed this question
