Question about Kwikset Locks & Locksmithing
How to spin turnpiece shaft on kwikset smartcode 916 because it's not pointing strait up
Posted by wtcgrip on
  • Don Slattery
    Don Slattery Jun 30, 2018
    I doubt you've still got this problem, but I had it today on my brand new install of my Kwikset 916. I discovered that the shaft was rotated like you describe. I inserted the batteries which freed up the turnpiece shaft. I manually rotated it to the proper direction then pulled the batteries. After that I installed the device, did a factory reset then performed the handing and inclusion per the instructions and it seems to be working fine now.
    Shame on Kwikset for not being available during normal business hours - which would have solved this issue for me right away.
    Shame on Kwikset for shipping these things with no help or troubleshooting for this which is extremely confusing.
    Good luck with your lock! All the best.
5 Related Answers
Coaltowner
  • 963 Answers
SOURCE: H do I reset all
This link will take you to the PDF image of the installation and programming instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
(PDF files require that you have Adobe Reader or similar installed on your computer
http://get.adobe.com/reader/ )
It's a good time to replace the batteries while you're reprogramming. Please review each step carefully, because it's easy to goof up this programming process, if you don't follow the procedure properly.
Posted on Jun 27, 2011
Coaltowner
  • 963 Answers
SOURCE: Kwikset Smartcode electronic lever, #
Here's a link to the Quick Installation Guide for your lock:
http://s7d5.scene7.com/is/content/BDHHI/smartcode-lever
When you scroll to the bottom of this page, it illustrates the four-switch slide switch internal to the lock. Switch 2 controls the 30-second auto-lock feature, so slide the second switch to the other position.
Posted on Jul 16, 2011
Coaltowner
  • 963 Answers
SOURCE: Kwikset smartcode deadbolt. The
Let's review the programming steps, in case you are overlooking something. This information was found at this link:
Important before proceeding: 1. Verify that position #2 of the "Settings
Switch" is in the OFF position. (Refer to section 11.) 2. Work with the
door open (away from jamb) to avoid accidental lock out. 3. Make sure
the bolt of latch is in the extended (locked) position
8. Automatic - Bolt Direction Determination (Door Handing).
IMPORTANT: DO NOT SKIP THE FOLLOWING STEP.
LOCK WILL NOT BE ABLE TO OPERATE PROPERLY!
? In the steps below, the SmartCode mechanism automatically determines the "door handing" and sets the proper direction for motor to rotate.
a. Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into the interior assembly (the tabs on the pack must face out)
b. When the unit begins to operate the bolt, release the "LOCK" button.
c. Do not disturb the unit for approximately 20 seconds until the interior Green LED flashes followed by a beep. During this time the system will drive the bolt several times, will determine "door handing", store data in memory and exit. It is very important that this process is allowed to finish properly.
Proceed with programming your Usercodes per the instructions.
Finally, here is the contact number for Customer Service At Kwikset. Call them if you still have the problem.
1-800-677-5625
Posted on Aug 04, 2011
Coaltowner
  • 963 Answers
SOURCE: my kwikset , smartcode lock
I can't help you directly, but I can direct you to Kwikset's customer service contacts. I'm sure they can assist you:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Good luck--and please provide feedback if this helps!
Posted on Nov 05, 2011
Coaltowner
  • 963 Answers
SOURCE: How do I change the lock to operate with my
Watch this video:
http://www.kwikset.com/Customer-Support/How-To-Center.aspx
Posted on Nov 08, 2011
Reset code kwikset
Here is the link to an excellent video of how to install, hand, and program the Smartcode 909. It includes switch-0controlled features of the lock:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 18, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
Need to reset code
Here is an excellent video of how to install, hand, and program the Smartcode 909. It includes switch controlled features of the lock:
Installation instructions:
Jul 17, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
Need to reset program numbers
Here is an excellent video of how to install, hand, and program the Smartcode 909. It includes switch-controlled features of the lock:
Everything you need to know about your lock!
May 06, 2012 | Kwikset 909 909-11P Venetian Bronze Smart...
Kwikset smart code turns too far After I enter the code, the door unlocks, and then keeps trying and making clicking sounds. It tries to go 3 times as far as it should. When it locks, it does the exact...
Yours is an unusual problem, and may be covered under warranty. Problems with "finish" and mechanical problems are covered; electronic problems are not.
Here is the link to the warranty information, which includes a contact number that I urge you to call:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Oct 28, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Gear spinning several times when locking the door.
Mechanical problems internal to the lock are covered by lifetime warranty. Contact Kwikset.
Sep 25, 2011 | Kwikset 909 909-L03 Lifetime Polished...
HOW CAN I INDICATE IF THE DOOR OPEN LEFT OR RIGTH? THANKS FOR YOUR RESPONSE
I'm including a link to the installation instructions for the Kwikset lock:
Pay close attention to section 8, the instructions for programming a door for left or right-handedness.
Apr 21, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset keypad deadbolt will not lock or unlock. Batteries OK.
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
Apr 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I have installed my smartcode lock correctly, but it still will not unlock? It locks well but will not unlock???? I have gone back over the steps 4 times and now I;m getting a little frustrated.. I have...
Here's a link to the Kwikset 909-15 information page:
http://www.kwikset.com/Products/Details/Electronic-Locks/909-15-SMT.aspx
Following the link to the Installation Guide:
On Page 8 starts the Frequently Asked Questions. Please pay close attention to the possibilities listed there--I think you'll find a solution to your problem there.
Customer Support: http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 20, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I lost the battery cradle. How can get another cradle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1-800-677-5625
Kwikset manual invites people to call phone number or visit website
http://www.kwikset.com/smartseries/smartcode.aspx
Oct 20, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Locks & Locksmithing Logo
981 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
