Question about Ricoh Office Equipment & Supplies
How can I solve SC 995 error for Ricoh Afcio 2027?
Posted by George Pappas on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
SC995 is a controller board not compatible error. You have replaced the controller board with the 2022 or 2032 board. All other boards and parts for this machines are the same. Only the controller board is different for all three models. But if you have not change the controller board and this SC995 appeared then the controller board is defective and need to be replaced.
Posted on Jun 26, 2018
5 Related Answers
Anonymous
  • 146 Answers
SOURCE: ricoh 2027 sc792 erorr code
This seems to be a finisher communication error. If you unit has a finisher on it check the connector.
Posted on May 26, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
quennie732
  • 422 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
quennie732
  • 422 Answers
SOURCE: On Ricoh Aficio 2027 say error SC 873, the machine print by her self
Needs to delete e-mail data in the hard drive sp5-832-008 Enter service mode and run this sp mode
Anonymous
  • 21 Answers
SOURCE: Sc 990 ERROR PROBLEM ON
replace drum, drum cleaning blade,charge roller. this will sort Sc 990
Posted on Oct 21, 2010
2answers
J'ai une ricoh mp c5501qu iaffiche sc819
North American website, we speak English :>)
I have a ricoh mp c5501 which displays sc819
Google Translate ici.
https://translate.google.ca/?sl=auto&tl=en&text=J%27ai%20une%20ricoh%20mp%20c5501qu%20iaffiche%20sc819&op=translate
The answer is NOT good!
AFICIO MP C551 SC 819 ( 5348 0x5554444F ) - Copytechnet
https://www.copytechnet.com > forums > 126200-aficio...
Jan. 13, 2018 - SC 819 is a fatal kernel error. Either the controller and possibly other boards were blown by the power surge or the components you replaced on ...
Ricoh Aficio 2035 SC819 Error Code - Copytechnet
Mar. 31, 2010
Error Code Ricoh MP5002 SC 819-00 - Copytechnet.com
Apr. 13, 2016
Error Code SC-819 MP 5000 - Copytechnet.com
Oct. 4, 2013
Thread: error SC 819 - Copytechnet.com
Mar. 30, 2017
More results from www.copytechnet.com
SOLVED: What is sc819 for ricoh aficio c4501 - Fixya
https://www.fixya.com > ... > Ricoh
Sep. 1, 2019 - Yeah most likely the Hard Drive, just replace them with off the shelf ones. Could also be the dimms, controller, nvram or firmware. I would unplug the HDD first ...
SOLVED: My machine ricoh mp c2352sp displays SC 819. I
Nov. 18, 2019
SOLVED: My ricoh aficio is showing sc819 - Fixya
Jan. 24, 2018
Ricoh mp 2550 error code sc 819 how to solve this problem
Nov. 21, 2019
SOLVED: Sc819 trouble/error in ricoh aficio mp5000. any - Fixya
Jun. 2, 2011
More results from www.fixya.com
Ricoh Aficio 480W - SC819 - PrintCopy .info
https://printcopy.info > brand=Ricoh > code=SC819
Ricoh Aficio 480W · Code: SC819 · Description: Fatal kernel error. Due to a control error, a RAM overflow occurred during system processing. One of the following ...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Code sc 990
sofware error, if your machine has A hard drive then format it, if that does not work then update the board firmware, also check the memory, one of those will solve the problem
3helpful
2answers
Problem with the Ricoh mp c2800 Ricoh error code sc 672,
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
7helpful
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
6helpful
3answers
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
12helpful
2answers
7helpful
3answers
Ricoh aficio 2027
3helpful
RICOH 2027 SC792 ERORR CODE
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
