Bush dishwasher model number DWS126S keepsswitching off during a wash cycle
SOURCE: Bush LCDS20TV007 will not switch on at all.
If there is no power at all , then it is a power adapter problem.
Test the TV on a different outlet, and if the power cord is fused check the fuse inside power plug.
If this does not fix the problem, then usually the TV has a faulty power board.
SOURCE: Bush LCD 2 will not switch on at all.
If the TV has no power at all, not even the led light on, and does not respond to remote or button, then the most common is a faulty power board inside the tv.
SOURCE: bush television model number idlcd32tv05hd
I have same problem, i had a faulty switch, changed that and now.....nothing :(
SOURCE: i need a user manual for bush washing machine
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Testimonial: "Thank you"
SOURCE: i have a Bush B320DTR
From experience this sounds like a failed Hard Drive. To test this - go into Menu->Setup and format the Hard Drive (obviously this will delete everything). This may clear off any corrupt data which may be causing the fault.
If this doesn't work then a new Hard Drive would be needed.
This is certainly fixable and we would be happy to help you: GoGoDigital
