Question about Kenmore Kitchen Ranges
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
SOURCE: Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Posted on Mar 26, 2010
SOURCE: Error message EO-F2 on Kenmore range/oven
model790.9503 gives f31 code
Posted on Jun 24, 2010
SOURCE: Kenmore oven/range doesn't work after turning power to my house off and back on.
a oven range is 240 volts , and will be a 40 or 50 amp double breaker make sure both breakers reset ,or you wont be getting but a120 volts to the range , not enough power .it looks like a single breaker but it is a double...
Posted on Jul 29, 2012
Jun 15, 2018 | Kitchen Ranges
Jul 03, 2015 | Kenmore 30" Freestanding Electric Range...
Jun 11, 2015 | Kenmore Kitchen Ranges
Aug 31, 2014 | Kitchen Ranges
Dec 10, 2013 | Kenmore 96422 / 96424 / 96429 Electric...
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oct 03, 2009 | Kenmore Ovens
Feb 06, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Jan 13, 2009 | Kitchen Ranges
Dec 05, 2007 | Kitchen Ranges
37 people viewed this question
