Question about Electrical Supplies
My mr. steam has turned on three times by itself. Any fixes for why its doing this
Posted by Aidan Bell on
1 Related Answer
Anonymous
SOURCE: Mr. Steam steamer is inppoerable
I just got this problem too, any solutions or a link to the manual?
Posted on Aug 12, 2010
My Mr. Steam turns on by itself. Is there an easy fix for this?
This most likely happens when you get moisture damage to the back of the controller in the shower. The moisture tends to short out the two pins on the back the just so happen to turn the unit on. During the time of install you need to, not only, apply it to the wall via the double sided tape but afterwards run a bead of silicone around the circumference of the controller to prevent moisture from running down your walls and into the back of the controller. At this point it would be best to kill the power to the generator and remove the controller from the wall slowly with a knife edge breaking the adhesive tape. Once you have it removed take some rubbing alcohol and some Q-tips and apply it to the 8 pins behind the controller. you can also quick dip the end of the control cable(with generator power off) into rubbing alcohol. This will clean any oxidation and dry out the controller, you may repeat this step if you like. Afterwards leave the controller out to dry for as much time as you can spare, then afterwards apply it back to the wall with double-sided tape and this time run the silicone bead around the controller to prevent the issue from reoccurring.
Aug 12, 2011 | Mr Steam Mr. Steam MS 81500E AutoFlush
I have a Mr. Steam unit installed in my shower room. When i turn the steamer on it sounds like it is working and the lights are on but no steam coming through!!
Hi I am with Mr. Steam Tech Support please call 1-800-767-8326 and ask for tech support we will also need you model and SN that are located on your steam unit
Nov 27, 2010 | Mr Steam Hardware & Accessories
Steam shower wont turn on getting a flashing temp on controller in shower
Hi I am with Mr. Steam Tech Support please call 800-767-8326 and ask for tech support. please have your serial number and we will be able at assit you in getting your unit up and running
Thanks
Mike
Mr. Steam
Product Support
Nov 14, 2010 | Mr Steam Ms Super 1e Steam Shower...
My mr steam is not steaming. We turned it on and 20 minutes later nothing happened. WE tried jump starting it with pouring cold water and that helped but it didn't reallly build up much of a stem before...
Hi my name is Mike with Mr. Steam Tech Support please call 800-767-8326 and ask for Tech Support and I will be more than happy to help you with you problem. please note I will need your model and SN Thanks
my ext is 1280
Dan ext is 1288
Mel ext is 1275
Sep 27, 2010 | Mr Steam Mr. Steam Steambaths Bulter...
We just moved into a house with a MS150 Mr steam. I turn it on and the display reads 110 for 10 mins then comes up with H2O on the display. What do I have to do? Nothing seems to happen.
Hi my name is Mike with Mr. Steam please give me a call at 1-800-767-8326 and ask for tech support. We will need you model # and SN # that is listed on your unit if you can be by your unit when you call and we will help troubleshoot your unit. In the mean time check the following 1) water is on 2) drain valve closed even if you have a auto flush close manuel valve for testing
Thanks
Mike Nail
Mr. Steam
Sep 18, 2010 | Mr Steam MrSteam MS150E Steam Generator
Mr. Steam won't start up
Hi my name is Mike I am with Mr. Steam Tech Support please give me a call at 800-767-8326 ext 1280 or email at [email protected] and I will happy to help you with your unit
Feb 19, 2010 | Mr Steam Mr. Steam Butler Package -...
Oct 06, 2009 | Mr Steam Mr. Steam Allegro Sauna Model...
Mr. Steam Prr erro
Hi, kindly check the connection of your temperature probe down to the main board maybe its loose.
Oct 03, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Steam Shower shuts down immediately now.
probably scale build up from tap water unfiltered. Scale caused by mineral deposits will affect safety systems and auto cut offs in the unit
Sep 13, 2009 | Mr Steam Mr. Steam Commercial Steambath...
Electrical Supplies Logo
71 people viewed this question
Top Electrical Supplies Experts
Marvin
Marvin
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
