We don't have this model but a quick check brings up a manual with tax setting. Hope it helps
https://the-checkout-tech.com/manuals/cashregisters/Royal_110dx_instruction_manual.html
SOURCE: I need to change the tax amount on my cash register royal 425cx
I found the user manual online and followed the instructions.
thanks.
SOURCE: I need to change the sales tax rate for my cash register.
Please find below the solution:
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
SOURCE: royal 325cx
Make sure you have flipped the switch all the way towards you to program.
Press 1 for tax rate #1. Press Tax Shift. Then put in your rate with 4 digits where 8% is 8000. Press Total.
If you want a department key to be taxable, press 001, press check, type in the price you want that department to be, and then press the department key.
If you want to make it not taxable, press 000, press check, type in the price, then press the department key.
SOURCE: how do I change the tax amount for Sharp XE-A101 cash register
9 => SBTL => Tax Number (1-4**) => @/TM => R => @/TM => Q => CA/AT/NS
"R": TAX RATE (0.0000% to 99.9999%) x10000
(Enter the rate in 6 digits. Leading Zeros may be ommited)
"Q": MINIMUM TAXABLE AMOUNT (0.01 to 99.99) x100
(Smallest amount for which tax must be collected)
**Up to 4 types of tax are programmable
Hope this helps!
