SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
SOURCE: The top burners all work fine. When I turn on the
IF THIS IS A NEW STOVE THERE IS A VALVE IF YOU PULL OUT THE LOWER DRAWER AND LOOK WITH A FLASH LIGHT YOU WILL SEE A VALVE AT THE REAR OF THE STOVEAT THE LOWER LEFT OF THE VALVE THERE IS A TINY LITTLE HANDLE WHICH OPENS THE GAS TO THE OVEN FLIP THE LITTLE LEVER SO IT IS IN THE OPEN POSSITION, THERE ARE NO MARKS SAYING OPEN OR CLOSED AND THE LEVER IS VERY HARD TO SEE
TRY THIS AND SEE IF THE OVEN STARTS WORKING
SOURCE: Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Testimonial: "Thank you very much for your help. I was looking for a thermocouple but that must be old school. I couldn't figure out what told gas to flow."
SOURCE: The pilot light on my caloric gas oven lights, but
there is a thermo copler ( temp sensor ) that tels the gas sensor "pilot is on give me gas" the copler needs to be cleaned or replased
