Ovens Logo
Question about Belling Ovens
Belling B170G Top oven/ grill stuck in on position appliance disconnected by gas engineer Can the control be stripped down and repaired or do we need a new control. I am a registered gas engineer.
Posted by Rob Jones on
5 Related Answers
Anonymous
SOURCE: belling synergie. oven
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Posted on Aug 19, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Thankyou.
Posted on Feb 02, 2010
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: oven not heating up [fan works]
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Thankyou.
Posted on Feb 11, 2010
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Posted on Mar 29, 2010
Testimonial: "Thanks "
The variable heat control of grill not working
possible low gas pressure or blocked burner tube if electric possible bad heating element
My belling wall oven model number 444440560 keeps going out after only a few seconds ignition how can I fix this thNks
which is going out top or bottom? may want to check the oven safety valve though it does not normally go out compared to other components. may have a bad igniter ( does it glow or lite up at all) it may still glow but not put out enough current to ignite flame? check with multimeter as well. if oven top is going out also check the igniter model or infinite switch
Belling classic 900e grill & hotplates not working
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Bottom oven and top oven not heating up
does the grill work? even if it does you need an engineer. the cooker will need to come out of the unit and the wiring and controls will need to be checked.
1helpful
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
4helpful
I have a Belling 652BL cooker. The grill and top oven have stopped working, but the rings and the main fan oven continue to work as normal. The troubleshooting section in the user instructions suggests...
ISOLATE MAINS POWER BEFORE OPENING SIDE AND REAR PANELS.
The grill and top oven have as discribed in the manual a temp regulator it is mounted on the side or rear chassis, this is probabily blown, they are normaly connected, when the devise goes faulty it stays open circuit, there are letters and numbers on this, take a note of them if you can read it. go to a local electrical store with the component, you should get a replacement, if however you have a multimeter, measure across the terminals with the meter on resistance, if no continuity, or contiunity to the case, the component is faulty. If however the component checks out working go to timers and remove the time on the auto timer for the top oven, visualy check the elements if the element have Black Grey spot, replace as it has blown, you can get spares at relativly low price you will need model and serial number of the appliance, from whitegoods.co.uk
hope this has been helpful
johnf1
2helpful
HOW DO YOU INSTALL A REPLACEMENT TOP OVEN GRILL ELEMENT IN A XOU500SS BELLING DOUBLE OVEN
remove the appliance so you can access the back panel. Make sure it is switched off at the wall and unscrew the nuts holding the element in place. disconnect the wires making sure to remember which wire went where. unscrew the screws holding the element inside the oven and remove. Reverse process to install new element
2answers
Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
