Question about Pentax Cameras
My Pentax Optio M20 the battery compartment lid has a broken latch/or it doesn't catch when closed.It has to be taped closed to operate and that doesn't hold very long. Thanks for any help.
Posted by Sonja Shetters on
5 Related Answers
Anonymous
SOURCE: pentax optio s5i
Hold the OK key for 5 seconds while powering on the camera. this unlocks the menu and key modes.
Posted on Dec 04, 2007
Anonymous
  • 66 Answers
SOURCE: pentax optio m20 .. on-off immdly
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Posted on May 30, 2008
Anonymous
SOURCE: REPLACMENT CD LID LATCH FOR DURABRAND MOD. CD-1493
http://cgi.ebay.com/CD-DOOR-LID-LATCH-LOCKING-DEVICE-STEREO-BOOMBOX-PART_W0QQitemZ220225587206QQihZ012QQcategoryZ48626QQtcZphotoQQcmdZViewItem
Posted on Feb 10, 2009
Anonymous
  • 9 Answers
SOURCE: Fuji S5000 camera problem....The battery door will
Also see post:
http://www.fixya.com/support/t1747423-fuji_finepix_s5000_battery_door
OZwombat suggests a aluminum bar holding the battery door shut, attached to the case with a screw in the tripod connector
604foxtrot replaced half the camera case with that of a used (broken) camera
Elastics, tape etc does not work
Posted on Apr 07, 2010
Anonymous
SOURCE: Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Posted on Dec 01, 2010
I need a new battery cover for my Pentax Optio M20
It might be too pricey, but you can order a replacement part from here.
Nov 23, 2010 | Pentax Optio M20 Digital Camera
The orange plastic clip that holds in the battery broke.
use some tape, or put a piece of something on top of the battery, when you close the battery door and latch it, it should hold the battery in place. That orange clip just holds the battery low enough that it comes in contact with the terminals at the bottom of the compartment.
Hope this helps
Jer
Jan 16, 2010 | Pentax Optio T20 Digital Camera
I have a problem with de softwaredisk from my Pentax Optio M20. i can do nothing with my camera. Where can i get the software for making it working?? the disk is broken
If you mean that you want to get the pictures off.
Buy a card reader...less problems, and no drivers as a rule for most operating systems including most Linux distributions.
There is no need for any of the software to be installed if you get a card reader and download a free picture editor..a number of open source programs for editing of pictures exist.
Sep 09, 2009 | Pentax Optio M20 Digital Camera
Jul 27, 2009 | Pentax Optio M20 Digital Camera
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
Pentax optio m20 .. on-off immdly
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Vista software needed for optio m20 camera
i require the software for my pentax optio M20 i now have vista
Oct 19, 2007 | Pentax Optio M20 Digital Camera
Pentax Optio E10
Do not interfere with the lens as it is out -dont try to push it back- this will wreck it. Take the batteries out and with the eraser at the end of a pencil polish the contacts at the bottom the the battery chamber. Do the same with the contacts in the lid Try a further new set of batteries. Insert them. close the lid switch on What happened? Nothing Then switch on again and this time gently push ther battery compartment lid. What happened?
Jun 07, 2007 | Pentax Optio E10 Digital Camera
Optio 555 Battery Compartment cover problem
My Optio 450 has the same type of cover and I am surprised how tough the cover is. I thought it would have broken by now. I suggest a call to Pentax would answer your question about getting it fixed. Alternatively, just leave it. The Plastic hinge should keep it closed
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Cameras Logo
Top Pentax Cameras Experts
halotheracer
halotheracer
Steven Wander
Steven Wander
Mat Kramer
Mat Kramer
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
