I don't know what testing you have done? Are you missing anything besides fuel? The fuel pump relay should be in under hood fuse box. Hopefully, the fuse box cover has a legend will give you the location? Your owners manual should have this info. If you don't have an owners manual, my.gm.com should have your owners manual, you can look at it for free. I usually use the index in owners manual, look up page for fuses.
Under hood fuse box .
SOURCE: 95 Buick Fuel Pump Fuse or/and Relay Locaton
fuel pump relay located in relay center under hood at center of firewall
SOURCE: fuel pump relay location
if not under the bonnet in the fuse box,, try under the steering wheel side of the dash,,,
SOURCE: Buick Regal dying
You have a problem in the fuel pump relay circuit for sure then. I'm betting the relay, but it could be that dropping resistor.
SOURCE: Where is the fuel pump relay location on a 97
under the hood, on the black box on the passenger side top engine compartment
SOURCE: How do I replace a fuel pump on a 1993 Buick Rega?
Follow the steps given below:
