Televison & Video Logo
Question about Alba Televison & Video
I've an alba tv combi and i switch it on and it switches it self off can i do anything simple
Posted by Jacqueline Phillips on
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Alba TV
I would suspect that the optical pickup is faulty. However Alba sets are manufactured in Albania therefore parts are not readily available.
Posted on Feb 03, 2008
Anonymous
SOURCE: Don't know how to switch from tv to av without remote
tried remote does not want to changetv just stays on enlish spanish french.mode.push enterselect does not work
Posted on Jun 12, 2009
Anonymous
  • 8909 Answers
SOURCE: Need a manual for a
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Nov 21, 2010
Anonymous
  • 3 Answers
SOURCE: Alba TV LCD4288DF 1080P Sound but
1. Check to see if the TV power outlet has power. Plug a lamp or something small into outlet to test for power. If there is no power in outlet, check your circuit breakers or power fuses.
2. Check to see if you have pressed the power button on the TV or on the remote controls. Check to ensure batteries are placed in remote correctly.
3. Check the setting of the picture brightness or contrast.
4. Check to ensure you have proper cable connections from your source going into your TV.
5. Check the volume settings on the TV.
6. Check to ensure the mute button is not pressed on.
Posted on Jan 20, 2011
W.L.
  • 2511 Answers
SOURCE: my 32inch alba tv will
Hi
try removing all the scart leads apart from the one with the dvd. One of the other leads is holding ie forcing it to another source.( Or turn off the other equipment.)
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Feb 22, 2011
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Lcd22advd switching to AV2 selection as far as i can tell it does not have a option to switch the only options it does have is tv,dtv/usb,dvd,ext,fav,hdmi,ypbpr,pc/vga also there is no button on the...
ok i bit confused to your problem, is it switching on it's own and is it always to AV2, or is it when you use the remote it switches over??
they should be a source button on the remote which allows to switch between connection modes. best regards
1helpful
ALBA tv/dvd combi LCD26ADVD only plays in black and white and does not respond to the remote anymore since my toddler got hold of the remote, please help
Remove batteries and disconnect power to reset. If that fails go to settings and restore factory defaults. Alba should have web site to help.
2helpful
Alba 16inch tv and dvd combi has turned black and white how can i change it back to coulor
Make sure the source is on TV
Press "menu"
quickly type "4725"
select "diagnostic"
choose "factory reset"
If this doesnt get colour back then its broken
I need codes for a remote ,BD512
there are no coides published for ALBA TV ,try Pressing SET (&hold)and (1) key ,indicator will flash eg. 4 times for Digit 4 etc,repeat this step ,with (2)key for the 2nd digit and (3) key for 3rd digit,good luck
Alba TV
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
