Question about Samsung Heating & Cooling
I am getting error codes e101 and a255 on Samsung air conditioner - what is the likely problem?
Posted by Rachel on
1 Related Answer
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
SOURCE: AIR conditioner samsung aqv12a error message "E101
ErrorCode = 101
Explanation and Checking points = Indoor unit communication error - checkwiring
Posted on Oct 27, 2011
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
R410A. What does code E101 mean?
R410A is a type of refrigerant; not a model number. To answer your question, we need the brand and model of the A/C.
Oct 31, 2015 | Heating & Cooling
E101
Out door "fan" can be replaced with any of same size but if u need to replace the unit then its all too tech and its tech details needs to be as same as the one that was installed. Outdoor unit doesnt only have a fan fir cooling but alongwith it condensor, compressor etc etc
Apr 14, 2014 | Samsung AS18A6RB Air Conditioner
E101
Room sensor problem. Replace in indoor unit
Nov 15, 2013 | Heating & Cooling
EROR E101
Room temp sensor defective. Try to reset by unplug and plug it with an intervel of 10 seconds. If it not clicked replace new sensor.
Samsung Vivance mini split flashes E101 and E416, I looked up explanation, but do not understand what it means and how to solve issue
Check and replace room sensor. Once it gets rectified, automatically E416 will go off which means not running of blower motor
Nov 14, 2013 | Samsung AQV12VBCN Vivace Mirror Finish...
ErrorCode = 101
Oct 18, 2011 | Samsung AS18A6RB Air Conditioner
Eror code 467 at samsung air conditioner vhat it mines.The air conditioner heat 45min or 1h end hes stop.At displej sayns e467
Error Code = 467
Explanation and Checking points = Inverter compressor rotation error. Interchange any 2 phase.
Jan 05, 2011 | Samsung Heating & Cooling
Heating & Cooling Logo
2,627 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
