Question about Apple iPhone Cell Phones
What is the Simplest way to Fix iPhone Error Codes 4013?
Yilia Yang
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
To troubleshoot iPhone error 4013, the following solutions are suggested:
1. Check USB cable and port
2. Reset all settings
3. Update iTunes
4. Free up storage space
5. Repair iOS system losslessly - UltFix
More: https://www.joyoshare.com/ultfix-for-win/
Posted on May 28, 2020
Howard Dalton
You can check the USB cable that it is faulty or not. Some days ago I have faced a sam error called and I take help from there https://iphonesupportnumber.com/blog/fix-iphone-error-code-4013/ If you want to solve your problem so you can have a look there and take help from there.
Posted on Dec 24, 2019
Phan Tien Tuyen
    Habit-Forming:
    New Friend:
  • 33 Answers
xiangnia
    Master:
  • Apple Master
  • 365 Answers
Try this way to fix iPhone Error Codes 4013. Solutions to Repair iTunes and iPhone Errors
Posted on Jul 27, 2018
How do I Fix iPhone Error Code 1015?
iTunes error 1015 is always along with the "plug into iTunes" screen stuck on iPhone. Indeed, that is the common error "iPhone stuck on recovery mode". Easy and quick way to fix it is to use the Re Boot. ... The error is that iTunes recognises a corrupt version of it's ios and will not complete signing.
Mar 16, 2018 | Cell Phones
Why am i getting error (4013) when i try to restore my iphone
The first thing you try should be change the USB port to which you connect the iPhone. Next up, change the cable that you use. Arguably, this has worked not for everyone but for a few people.
As an extreme measure, you can also try updating from some other computer which has the latest iTunes installed.
Backing Up and Going Into Recovery Mode
If you are trying to update the firmware without doing a clean restore but running into this error (even after changing the cables), it's time to cut the chase. This method is usually recommended as the last-thing-to-try but I think it's easier to get this done with right away.
  • Connect your iPhone to the computer. Fire up iTunes.
  • Backup your iPhone.
  • Now disconnect the iPhone, quit iTunes.
  • Put the iPhone in recovery mode. The short version goes like this: press and hold power and home buttons till the screen goes blank.
  • Open iTunes on PC.
  • Connect the iPhone. iTunes should indicate (through a dialog box) that an iPhone is detected in recovery mode.
  • Now go ahead and restore the device as new. This will erase everything but you will have the backup to restore from.
Some Notes
  • Occasionally, the error seems to vanish when people update to the last iOS 6.x version and then update to iOS 7. (This applies when you are on iOS 6.0, 6.1).
  • Clear out apps and app memory to free up space on your iPhone. Although this sounds very unrelated to this error, it has helped.
Jun 22, 2014 | Apple iPhone 5c
Error message 6000....alarm flashing....check printer I tried the turn off and back on to reset....did not fix
There are a number of problems that can cause a 6000 error.
The simplest is a paper jam or it could be associated with your LAN connection if you're runing Ad-Ware or a registry porblem.
Try disconnecting your LAN cable (if you're using one) and try staring your printer and see what happens. You may need to reset the memory error codes.
To reset the printer and release memory error codes.
1. Press and hold the Resume for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then replace them.
4. Close The Cover
5. Turn Off
6. Then Turn On again
Jun 15, 2011 | Canon PIXMA MX310 All-In-One Printer
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Open Questions:
How do i Bypass MDM Profile on iPhone its also available for iPad? Top Distant Service for MDM iDevices Remember how frustrated you feel when you want to order a service online and have to wait for hours and hours sometimes even days or weeks to hear back from the seller? This is not the case with the exclusive MDM bypass because this service is instant 24/7. You order and become unlocked instantly. No need to wait and worry about anything. There are some facts you should know about MDM unlock: 1 Order the service ONLY if you have MDM profile lock on your iPhone or iPad. This option is available for MDM locked gadgets only. There is no refund if you place wrong order hoping to bypass iCloud lock on the iPhone or iPad. Do not mistake MDM unlock with iCloud unlock, please. 2 Use the exclusive service when you ARE SURE that this is exactly what you need. 3 The results are TEMPORARY. The MDM Activation lock iPhone screen becomes unlocked temporarily. It is not a permanent fix. When you update to newer iOS or restore the iDevice the lock will return. Temporary? How to Unlock Again? Don't worry about the temporary fix because when you order the 24/7 service your IMEI is added to the activation approval list. What does it mean? You can manually return to MDM unlocked state by backing up the device after restoring or upgrading to the latest iOS version. Just remember to backup the unlocked phone or tablet device via iTunes or iCloud right after you receive successful MDM Activation unlock result. There are no guarantees that the service stays on forever. No one can guarantee anything with Apple future updates and changes. But we do guarantee that if you create a backup of the unlocked iDevice you will be always able to restore from this backup and get rid of MDM lock in the future. iActivate application is the quick and safe method of removing iOS mobile device management profile lock also called MDM lock. The app supports the following gadgets models: All iPhones including all versions and any iOS firmware All iPads including all models and any iOS firmware All iPods Touch including any version and iOS software MDM Lock Verification It is easy to check if your iPhone, iPad or iPod Touch is mobile device management locked or not: Step 1. You should launch iTunes on your computer. Step 2. Connect the gadget through USB cable. Step 3. If you see the text similar to Company name will automatically configure your iDevice - it means that your gadget is MDM locked. Step 4. Besides you will be asked to provide the name and passcode for your corporation profile. In other words, this is 100% evidence that your device is enrolled to Apple DEP MDM program. How to Bypass MDM Lock via iActivate Use iActivate program to distantly and instantly remove mobile device management configuration profile: Step 1. Figure out your gadget's IMEI number. This is easy to do by dialing *#06# - the IMEI will be automatically displayed on the screen. Step 2. Download iActivate tool through this link: http://iactivate.host/downloads/ and submit the order with your IMEI. Step 3. Run iActivate and click on Start iActivate Server option. Step 4. Connect the mobile gadget to your computer. Launch iTunes. Activate the MDM locked gadget as you would usually do. Make sure iActivate and iTunes are running simultaneously. Step 5. Once you have successfully bypassed the MDM lock you can click on Stop iActivate Service. You are done!
Sep 13, 2017 | Apple Cell Phones
Cell Phones Logo
334 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
