SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
SOURCE: the start/pause button is flashing
timer is failed. replace the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
SOURCE: My electrolux EWF 1074 washing
Hi First
make sure that nothing is blocking the drain pump assembly located inside the
bottom of the unit, after this test the door lock-switch assembly. If the door
lock-switch is also fine then the control board should be replaced. Hope this
helps...please post back for further assistance. Daniel
SOURCE: ELECTROLUX EWF 1282 flashing Start/Pause. Door
Hi- answered on your second posting ;-0) John C
Hello terry_gwen - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. I understand that the filter has been cleaned, however, if you noticed a humming noise, it could either be a clogged drainage hose, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Hello - Are you certain the error code is L60? This manufacturer does not have any (L) error codes for any washer or other units.
