Question about Rio Computers & Internet
My Rio Bluetooth touchpad keyboard when I connect with The Bluetooth dongle supplied is asking for pin before device pairs but there was no pin supplied when bought device so what do I do please help
I'm connecting by Bluetooth using the dongle that come with device when I do devices search with Bluetooth it finds it fine but when I press connect it trill try then displays message saying incorrect pin that's when it is found when search for it in Bluetooth 9 times out of 10 no device found comes up after trying to connect keyboard please help resolve this.had now for 6month and not bin able to use yet
Posted by Kim Hill on
Joseph Wright
  • Rio Master
  • 1,640 Answers
Something I found with a Google search:
Entering the code "0000" will often work. If not, you may need to check the device's documentation (or perform a web search) to find the PIN it needs. By default, after the devices are paired, they'll automatically see each other and communicate when they're both powered on and have Bluetooth enabled.
Posted on Mar 27, 2018
5 Related Answers
Anonymous
SOURCE: don't know the pin to set up my bluetooth
use zeros.
Posted on Jan 16, 2008
Anonymous
SOURCE: RIM 8310 Curve to desktop bluetooth "connection" problem
I was able to connect in safemode and complete the restore of my data that was backed up from my old BB and everything worked just fine. Safemode is the only solution I found that worked. No one at Rogers (provider) was able to help, so much for support.
Posted on Jul 02, 2008
Anonymous
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: [email protected] Subject: omnitech bluetooth
Posted on Mar 09, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: Blackberry Curve 8330 can not find my bluetooth headset
Turn the 360 off.
Then turn Bluetooth off, then back on the Curve.
Then turn the 360 back on, input the code when asked to due so.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jul 24, 2009
njvinod
Vinod Kumar
  • 1462 Answers
SOURCE: Cannot connect to bluetooth device
Hi, first
You have to enable the Bluetooth device to scanning mode,
To do this, press and hold the power button of your bluetooth continously for 10 seconds, you may have a stable LED, this shows that its in discoverable mode,
Now perform scanning and you may get your device and you can pair and make it work with default passcode of 0000 or 1234 or 8888
Please RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Oct 25, 2009
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
I want to use this head set as playback head phone with my laptop (having bluetooth) while using windows 7 proffesional x 86 edition is it possible? if possible then how can i use this one please reply...
Tool; CSR bluetooth dongle 2.0, got from store for only $2.50.
Install Toshiba Bluetooth stack v7.00.10(T) driver Win7x64 (search in google to download the installer). from OFF state of your BH-214, press power button until LED flashes quickly,do not release the button, stay press until LED flashes red & blue alternately slowly.On ur PC,->Add new device, then your PC would detect BH-214 as headset. Work fine with my BH-214 to connect with PC through BTooth dongle (A2DP 1.2 (btooth audio profile) & AVRCP (player navigation control profile)) & at the same time with my phone (HFP, HandsFree profile).
Dec 20, 2010 | Nokia BH-214 Bluetooth Stereo Headset
The Device Nokia BH-214 is not always detected by my PC or Mobiles ....how do i resolve the issue
Install Toshiba Bluetooth stack v7.00.10(T) driver Win7x64 (search in google to download the installer). from OFF state of your BH-214, press power button until LED flashes quickly,do not release the button yet, stay press until LED flashes red & blue alternately slowly.On ur PC,->Add new device, then your PC would detect BH-214 as headset. Work fine with my BH-214 to connect with PC through BTooth dongle (A2DP 1.2 (btooth audio profile) & AVRCP (player navigation control profile)) & at the same time with my phone (HFP, HandsFree profile).
Dec 12, 2010 | Nokia BH-214 Bluetooth Stereo Headset
How should i send or receive data from other mobile.
  1. Use a cellphone with Bluetooth (wireless connection), or even a USB connection (which is a computer port). These are all good ways to communicate with other devices.
  2. If your computer does not have the hardware for a Bluetooth connection, then buy the adaptor, sometimes called a 'dongle'. The adapter plugs into a USB port. It will be quite cheap, something like 10 to 20 American dollars. This adapter will have software for the connection process, which lets you transfer files from the computer to your phone, and the other way around.
  3. Make sure your computer is equipped with Bluetooth technology (either integrated into the machine or a USB dongle) and active.
  4. Turn on Bluetooth on your mobile device.
  5. Turn on your phone and go into 'Settings' in the Main Menu
  6. Keep going down until you find 'Bluetooth' (Sometimes it may be under 'Connectivity)
  7. Click on it and find 'Turn Bluetooth on' (or something similar) and press 'On'. You can now send and receive files. Once you receive a file, it will most likely be under 'Received Files'. This option can often be found in the Settings or Connectivity menu of your phone.
  8. Pair your computer with your mobile device by making both devices discoverable (also known as visible or unhidden) in the Bluetooth options. Once both are visible, search for Bluetooth devices on your mobile phone
  9. Locate the name of your computer in the results list and select it.
  10. Enter a 4 to 8 digit passcode of your own choosing and press continue.
  11. Once your devices are paired, you can send and receive files.
  12. There are several methods to send a file to your mobile device. One method is to copy the file from your computer, navigate to your mobile device (often found in My Computer or My Bluetooth Places) and then paste the file to the phone. Another option is to right-click on the desired file and select Send To --> Bluetooth Device --> (mobile phone's name).
  13. While the file is being transferred, you should see a progress bar on your computer and/or phone. Once the file is finished transferring, a message stating such should show up on your device's screen.
  14. Find the transferred file on your mobile phone by using the phone's built-in file explorer.
Oct 20, 2010 | Computers & Internet
HK-760 Bluetooth dongle, pairs with my HP computer but after inserting the passkey, the computer starts searching for the peripheral device drivers without which a connection between my jabra VBT2050...
This device, according to the Jabra website, is intended only for phones, not PC's. The PC is searching for a driver in order to know how to communicate with the device. Since the VBT2050 does not have the necessary software contained within itself, the PC starts searching for device drivers. There are none that I could find on the Jabra website, so I don't think it is intended to be used with a PC.
Feb 20, 2010 | Adapters.com Bluetooth USB Adapater, USB...
Cannot connect to motorola phone tools using bluetooth
in the phone itself, you have to search for bluetooth devices and accept the found device in order for it to work, once set-up searching is not needed for that device again
Feb 12, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Bluetooth connection to pc suite
There is an solution for this one.
Try this:
Don't connect or search your phone by the bluethoot dongle
settings. Make sure that the program is running and the bluethoot
dongle is alive.
Now find the bluethoot settings on your phone.
Before you choose for new devices make sure that your
phone settings MY device visibillity is on.
Go back to the bluethoot menu and choose Search for new device.
Your laptop will be found by your phone.
A screen appear on the laptop and ask for a password to get connected with your phone.
Choose a password in numbers and use the same numbers as you did putit in on your laptop on the phone.
When this is done the laptop will find your phone.
now you can turn of the visibillity of your phone and make the
device profile on your phone ( your laptop ) authorised.
So you do not have to put in the password everytime when you
make a connection with your laptop.
I hope this will helps.
Jul 12, 2008 | LG KU990 Viewty
Not able to connect Jabra BT 125 to Laptop
Correction to the above note...
You can connect your Jabra 125 to your computer's audio output and listen to music via the ear piece. You need to make the adjustments in the control pannel. Set the audio/sound output to the blue tooth. You also need to sync the earpiece to the pc via a dongle or bluetooth adapter on the pc. Works great...
Jimmy
www.CLSONLINE.org
Feb 16, 2008 | Jabra BT125 Headset
Computers & Internet Logo
94 people viewed this question
Top Rio Computers & Internet Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Rio Computer and Internet Expert? Answer questions, earn points and help others
