All because such manufacturers are trying to make a unique texture of the tiles, but not spending money on the quality of materials that they use for production. That's why it turns out that the tiles are beautiful, but the quality is not very good. We ordered for ourselves external fibre cement board quality tiles is excellent, as well as quite a beautiful design of tiles and using such a tile can give a unique design to the building. If interested look at the Internet photos of buildings where similar tiles are used.
Can anyone give advice on choosing fiber cement tiles? Which manufacturer now makes quality tiles based on price and quality? I just read somewhere that even very expensive fiber cement tiles for cladding a building may not be of good quality.
Hello, Jay -
So . . . you are working in housing construction in Springfield, Missouri and the lead contractor does not know the requirements for mail boxes. Plus, your question landed in the Fixya.com category for land line phones.
Talk with the foreman of the construction company and ask your questions.
SOURCE: I need to build a single phase to three phase
You will need a rotary converter for this, or a single phase motor. A three phase motor absolutely cannot be made to run on single phase otherwise.
SOURCE: Is the AE9.5-RE model 208-240 Volts, single phase or tree phase?
That is a single phase hot water heater. Hope this helps
SOURCE: wiring diagram for three phase power with two 200 amp service boxes inside building
This work requires a license (or qualified person) everywhere that the National Electrical Code is enforced.
If you're asking how to wire a single phase 200 amp panel from a larger, 3 phase panel of the same voltage - ONE way is to install a 2 pole - 200 amp breaker into the 3 phase panel. Provide 4 correctly sized conductors with the correct insulation in a cable or conduit between the 3 phase panel and the 200 amp single phase panel. Two of these conductors should be black and red (for 120/208 volt system) and connect to the 2 pole - 200 amp circuit breaker terminals, the third should be white and connected to the neutral bus bar. The forth should be green and is connected to the neutral bus bar as well but *only if* it is "service equipment" If it is a "main or sub panel", the green wire should be connected to the ground bus bar. The other end of the conductors should be terminated in a "main lug only" 200 amp panel. The back and red connect to "line 1" and "line 2" bus lugs, the white to the neutral bus bar that is NOT electrically connected to the panel enclosure (do not install the screw or strap between the bar and enclosure). The green must be connected by installing a separate bar that is securely fastened both mechanically and electrically to the enclosure for ground connections.
There is a great deal going on here - and plenty of variables that can change how to do this work, safely and correctly. This is an example of just ONE of many different ways to do the work for a particular installation. There is no one way that works for all situations. If your situation does not support this method - you will have an unsafe installation and subject the building and people in it to a dangerous fire / safety hazard.
Please, consult a licensed electrician before attempting this work.
SOURCE: want pictures of step by step on how to build a model tree house
This is the car and truck section. You probably should research this with google or one of the internet search engines.
