SOURCE: I would like to buy an Owner's Manual for a 2002 Olds Intrigue
try http://store.payloadz.com serch for your vehicle, I think its about 5 bucks
SOURCE: CAn I hook up externa speakers for the jute box Rock Ola 480
That depends if you have skp out or a head phone jack .If so the RCA out jack would
have to go to the input of your amp.
or the head phone jack could directley
drive a small set speakers , the 1/4 or 1/8
head phone jack plug wire from a old
pair of head phones would be strip and
wired to small external spk , or driectly
to the auido amp But keep the volume
on the Rock Ola very low if you
chose the latter ,as not to over drive
your amp.
for spicifics
SOURCE: i have a 1965 rock-ola starlet jukebox and it will
It won't reject because it needs to have the gripper arm complete the motion before the microswitches on the cam are in the right position.
It has either seized up or blown a fuse or both.
SOURCE: Will not play cd's and gives error code
hi there i have a nsm galaxy juke box does anyone know what error 74 means many thanks steve
SOURCE: noisy bubbler on rock-ola jukebox
Lubricating the motor MAY resolve it or the motor bearings are probably worn down. A possible solution might be to remove the motor and slightly drill or file out one of the mounting holes, permitting you to adjust the position of the motor just enough to allow for the lash in the gears to be corrected. Essentially to lube things, and the rubber drive rollers wear out also should be replaced.
