Question about Pro Computers & Internet
I just purchased lock box pro because entries in basic lock box were scrambled. I thought it would update automaticaly. How do I transfer info from basic App to Lockbox Pro?
Posted by Shane Ellis on
Eric Sutherland
    Master:
  • 665 Answers
5 Related Answers
Anonymous
SOURCE: Windows Updates will not download...
Version 10.04 will not fix the problem with Windows Updates, and 10.04 will only update from a 10.03 version. Its not recommended unless you're using Fax Sharing and Windows XP.
Its possible you've overwrote some important system files in the process of copying files, but WinFax itself would not cause the problem.
Posted on Apr 24, 2008
Anonymous
  • 34 Answers
SOURCE: had to reinstall quick books pro 2002 in new
Go to: http://sharedldfp.intuit.com/pub/quickbooks/2002/
Posted on Feb 02, 2010
tmburke
  • 76 Answers
SOURCE: Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool: lost key: Sentry 1100 strong box....
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Posted on Jul 02, 2010
Anonymous
SOURCE: I just upgraded from the
Hey, I had a similar problem with you. I only wanted to transfer my file to the computer so I link my Iphone with the PC and if you click your Iphone on Itunes and go to apps you can see recorder there. You can transfer your files directly to your PC and you can open the files using Itunes or Quicktime.
Posted on Feb 05, 2011
sjaak217
sjaak217
SOURCE: lockbox export/import connectivity problems
Use the IP address of your iphone (check Settings/Wifi/network details) and add :88 to this address.
Posted on Dec 15, 2012
In regards to my last question in which coastrider replied i have a pirated copy of xp pro dlxp ultimate media center edition.im very confused now becaese i was on microsofts site they had a scan to see...
I don't know what the original problem is, but if you are getting all the updates and Microsoft says you have a genuine copy, then that is what it is.
If winver says you have XP Pro, then that is what you have.
Sep 02, 2010 | Microsoft Windows XP Professional
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
Box crashed
we have no info on this type of box, sorry
Oct 05, 2009 | StarTech.com StarView SV211K 2-port KVM...
The movies channel and sports is scrambled
these units are not ment to be used as a cable converter for the more premium service ;just some of the basic ones , it sucks but sorry you'll need a regular cable decoder box also.
Apr 02, 2009 | Televison & Video
Power door locks
You will need two power door lock actuators. They are pretty easy to install and would be wired to the new alarm system.
From what I see, decent DEI ones go for about 50 a pop. Atleast, in my area retail. If its something you are interested in, as of Aug 18th I still have two BRAND NEW in box that I never used on a client's old honda DX. Both the high powered versions.
Hit me up if interested sometime ddowling06 at g mail .com
Jul 08, 2008 | Viper Security and Remote Start System...
Eurovox v
Hi thanks for the info i got a box off my mate that he used and this wouldnt work on my line but my virgin box works fine so it looks like they have clued up and managed to scramble the signal. Maybe someone will find a way of doing the newer boxes and solving your problem.
I cant see the firmware programmes being able to get round the scrambled signal on the older boxes so i think its a case of waiting till the new boxes can be sorted if i hear anythink ill post back a message for you hear.
I spoke to a mate who works with virgin as a tech and he said ha has seen a couple of boxes that he took of people that could view all channels so what he done was kept a box for himself and he is going to get back to me when he gets chance to look at whats been changed on the box.
Till now he thought it wasnt possible but when virgin called him to collect the boxes as they were being used when they wasnt paying subscription cus he said virgin can see what your watching now where as the ntl boxes couldnt do this.
But he said they wouldnt have got caught if they paid for the basic package because he said virgin found out the signal was coming from their addresse without them paying for using the box, so he said if you paid for the basic package then you wouldnt get caught so what hes going to do is find out how they hacked the box and then he will let me know ok then ill let you know ok.
The only problem you might have is getting the new virgin box he said the only way he can see round this is if you piad for basic package then have the box upgraded then at least virgin would know you had a box and would be less obvious what was happening ok.
So ill post message back for you in the next week or so ok
so speak soon, also if you find anything out then let me know ok
Apr 12, 2008 | Televison & Video
Scrambled footage
if you are captureing through the fire wire port, it could be the port is bad. Just to make sure, see if you can get ahold of a "Blue Box" one of those analog to firewire converter boxes, and see if it comes out clear then. if it does then I am 100% sure that it is the firewire port.
Feb 20, 2008 | Canon XL1S Mini DV Digital Camcorder
Feb 07, 2008 | Symantec WinFax Pro for PC
Line 3 dissapearance
in the manual does it describe how to reset to manufactory defaults and have you got your hook-up to your digi box via a fully wired scart if so this cable is causing double feed back wich means signal is senging info from dig box back to scramble setting use a one way signal scart to recorder this is the lead i use to eleminate settings from being scrambled and a clear signal from dig box this is also updates time automaticly when you get back to settings menu turn off auto clock set this will stop time from going on 1 hour hope this will help
Aug 10, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Computers & Internet Logo
162 people viewed this question
Top Pro Computers & Internet Experts
k24674
john h
Andrew Taylor
Andrew Taylor
Are you a Pro Computer and Internet Expert? Answer questions, earn points and help others
