Question about Minolta Office Equipment & Supplies
How to fix top margin on minolta magicolor 2550 printer.
Paper jams while printing
Posted by jrivero56 on
  • Norman  J Weimar Jr
    Norman J Weimar Jr Apr 08, 2018
    Hi jrivero56, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Jamming where?
5 Related Answers
Anonymous
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
Anonymous
  • 19 Answers
SOURCE: Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
Posted on Aug 30, 2008
Anonymous
  • 183 Answers
SOURCE: where is the drum reset fuse located on the Minolta 2530 DL print
you can find all details with picture shot on following website:
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2530dl/user_e.pdf
please post back if any changes and vote all answers.
good luck
Posted on Feb 07, 2009
Anonymous
  • 48 Answers
SOURCE: KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Posted on Jun 01, 2009
Anonymous
  • 210 Answers
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
Posted on Jul 09, 2009
Top margin on the printed page is off 2-3 in. Ater printing skows paper jam but there isn't any.
might be that there is problem with media (paper) size ensure you not a metric size paper or the printer properties are set for metric A 4 is 8 1/2 x 11, A 3 is 11 x 17
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Magicolor 2400w top margin off
I spent a while troubleshooting a similar issue on my 2400W. It turned out to be the SL2 registration solenoid, which failed to engage properly. The purpose of SL2 is to stop the page temporarily until it lines up with the image on the transfer belt. Unfortunately, SL2 is very finicky, the foam pad that stops the lever flattened too much and got sticky, so the lever wouldn't engage anymore, and the paper went straight through instead of pausing briefly when using B&W mode driver, resulting in the shifted image. In color mode, I got no image, just a "paper jam at transfer roller" error message, even though the paper came out empty without jamming. I had to adjust SL2 a few times to get it to work optimally, i.e. with minimal travel and maximal holding force. Then everything worked well again.
2300W print page alignment
try reloading the driver go the web site below get up dated drivers
Self Help Product Support Konica Minolta Business Solutions Inc
My magicolor 2550 won't print in color
PLEASE CHECK ON PRINTER PROPETE AND CHECK MARK BLACK
5helpful
2answers
Error during 1st install of paper
konica minolta magicolor 1680mf service call 0094
Help me
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Problem with konica minolta paper margin
You don't have any solution but to increase the above margin to be equal as the bottom margin. To successfully print the pages, this printer need a larger bottom margin compared with the above margin. Just use the 'Center on page' option from your graphic application.
Paper jam, cleaner kit
If the paper is not situated perfectly in the tray, and it cannot grab the top sheet easily, mine will give the paper jam message. I just adjust the paper in the tray, then open one of the doors, front or back, and close it again, and it usually fixes the "Jam".
Paper jam
open doors and find these solenoids, clean them and make sure they are moving fine, its not so hard. just step by step move with paper and find out where the solenoids are. solenoids aren't expensive so if its a solenoid problem you should fix it
Top Minolta Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Mehandi Husain ...
George Mclaughlin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
