Televison & Video Logo
Question about RCA Televison & Video
How do I turn off the describing video on my rca roku 7510x
Posted by Ginette leveille on
Clive
  • 4,362 Answers
Use Roku Accessibility Settings
You can also turn off narration on your Roku from the Accessibility options. From the Roku Home screen, go to Settings > Accessibility. Under Audio Guide, select Audio Guide or Screen reader. Highlight Off to disable this feature.
Posted on Jan 10, 2023
I have a onn Roku TV that I need the programming code
Remote Control Codes For ROKU TVs with setup instructions
www.directutor.com > content > remote-control-codes-r...
Roku remotes simple interface revolutionize your TV, adjust the volume, mute, control your streaming with one roku remote and voice search ... Instructions for Roku TV remote code programing using Universal Remote. ... Cable Provider: ONN. GE Universal Remote Model 24922: 2891
Remote Brand: Remote Codes for TCL Roku TV ...
ONN: 3851
RCA/Voxx: 12434,387, 12049
I have a LG Plasma 50 inch TV, I have Roku hooked in HDMI 1, when I turn on TV the screen is black out with invalid format flashing across screen, how do I fix it.?
you will have to go into the roku settings and change the resolution to one that works with your tv
if your roku has rca jacks hook it to that temporally so you can see a picture on your tv to change the setting
No hdmi audio output except Roku 2.
You didn't mention whether you switched inputs on your TV for the different devices. Fix could be that simple.
RCA TV Converter Box DTA800B1. Codes for roku tv
For a Cablevision cable Provider the remote controller Model Number is UR2-CBL-CV04 and its remote device unique codes for Roku TV become 031, 081. To get a Charter Cable Provider the remote control Model Number is usually UR4U-MDVR-CHD2 and its remote control codes for Roku TV be 11756, 11602. The user on find their respective remote controller code, have to activate their Roku account using enter Roku activate code to get started on streaming their recommended shows.
For a new Cox Communications Cable Provider the remote control Model Number is URC-8820-MOTO and its remote control codes for Roku TV be 1756, 2360. For the DirecTV Cable Provider the particular remote control Model Number will be RC65 and its remote control codes for Roku TV be 11756, 10818. For a Dish Network Cable provider the handheld remote control Model Number is 21.1 IR/UHF and its remote control codes for Roku TV be 535, 556.
The ONN Cable Supplier the remote control Type Number is ONA12AV058 in addition to its remote control rules for Roku TV are 3851, 3201. Once the consumers remote controller are programmed with the respective codes then the user also have to activate their Roku accounts using enter Roku activate code to start out enjoying their preferred streams.
Hope you find your own appropriate code for your cable providers. For any help on adding the RCA Roku TV codes call our technical support staff members through toll-free numbers +1-855-804-1313 or visit them at roku.com/link
Roku has been working for months tv screen turned black today in middle of program now nothing. Roku is working because power indicator lights up but nothing on screen.
Check the video output cable (HDMI or composite/RCA, etc.) from the Roku to the TV, to make sure it's still connected. Verify that you're watching the input on the TV that the Roku is connected to. If that doesn't work, contact Roku support. I hope your unit didn't just die.
1helpful
I only have on set of white, yellow & red receptors on back of tv. There is a set (entitled Video 2) on the side of the tv.1st - can I attach the Roku to the receptors at the side of the tv or2nd - i...
You didn't say which Roku you have, so I will assume you have a Roku 3 since it's the only one without RCA output jacks (the red, white, and yellow jacks you mention). You can return the Roku 3 and get a Roku 2. You can only attach the Roku to a switching box if 1) the Roku has the RCA outputs and your switch has A/V inputs. If you DO have the Roku 3, then you may be able to purchase a HDMI to RCA cable from Amazon http://www.amazon.com/HDMI-RCA-VGA-Cable-1-8m/dp/B002ZUI68G
Program RCRPS06GR for Roku
My roku stick remote broke and I want to program my universal remote RCA rcrps06gr to program roku can I program it
I am trying to install ROKU video streamer into my Sharp TV model 27KS300. Roku says to plug their red/yellow/white RCA cable into the video in ports on your TV. I do this but nothing happens. I am...
Yes these are the same yellow white and red ports that you would use to connect your DVD player. I believe this television has one port in the front and one in the back. I might be wrong but I believe video 1 is in the back and video 2 is in the front. If you have tried video 1 and video 2 making sure you have pressed the video/input button to select the proper one after connecting your Roku then you have done everything properly. Make sure to try a different RCA cable to make sure it is not the cable that is causing the problem. Also try the Roku on a different television because if it is working on a different television with the same RCA cable then you'll know that it isn't compatible with this particular television.
Can't get Roku N1100 to work with Samsung LCD. Worked fine with older style TV. DVD input works fine. Connect Roku....Nothing. Samsung LN32C350. Attempting to connect with RCA style connectors,...
Make sure you select the correct input for your device. If you are using RCA cables then select the RGB option on your inputs, or it may RCA as a connection. If you are using HDMI then make sure that is selected.
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
