Question about Samsung Televison & Video
How do I turn off captions on my Feych TV TV programs.
I have a Samsung smart tv and a harmony remote The online suggestions say go to set Jon and scroll down to captions - there does not appear to be an option around captions. Thank you.
Posted by Sally-Anne on
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: HOW TO REMOVE CLOSE CAPTION FROM SMART SERIES TV
on your remote go to cc push that until it sayes closed caption off not positive but pretty sure
Posted on Jan 11, 2009
Anonymous
  • 126 Answers
SOURCE: how to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
Posted on May 18, 2009
Anonymous
  • 101 Answers
SOURCE: samsung PN58b530 tv and harmony 550. When setup
Samsung TV's have Anynet automatic input switching. This severely conflicts with the Harmony Remote as they both do the same jobs; Switch inputs automatically. We would like for you to disable this feature on your Samsung TV using your original remote, so the Harmony Remote will work properly.
Disable Samsung Anynet+
1. Press your Tools Button.
2. Scroll down to Anynet and press your Select Button.
3. Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4. Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote.
Posted on Feb 04, 2010
Anonymous
SOURCE: Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Posted on Jul 23, 2010
Anonymous
SOURCE: I can not turn off
I have direct tv, and had the same problem. After an hour on the phone with the worthless tech, I gave up. Finally I figured it out. First of all do you have closed caption problems or is it "subtitles". mine turned out to be direct tv subtitles, not closed caption. I hit the yellow button on the direct tv remote, and presto. Subtitles was set to the on position. changed it to off, and what do you know. fixed.
Posted on Jan 04, 2011
How do I get closed captioning on my samsung 6300 TV
A Google search suggested this:
To turn on and set the Closed Caption function options, follow these steps:
  • Turn on your TV and STB.
  • Press the Menu button on your remote control. ...
  • Highlight Setup, and then press the OK button on your remote control. ...
  • Highlight Preferences, and then press the OK button. ...
  • Highlight Caption,and then press the OK button.
2answers
I have a Samsung smart tv. We use a harmony remote to control it. We are unable to shut it off, adjust volume, change stations
There is a code for every tv that you will have to load into the remote. Ask Radio Shack person how to get your code onto your remote.
I have a Sony bravia tv and. Harmony 1 universal remote. How do I turn on closed captioning?
The problem with universal remotes is that they are just that - universal. They are good at doing all the normal things that TVs do, but often cannot or do not have the programming to do the subtle things that the manufacturer's remote can do.
My samsung smart tv shows a mute indicator that just kills the sound but the only way to get it back is to unplug the att pvr and wait 4-5 minutes
this not a problem coming from Remote control, this a problem from yuoTV smart.contact your supplier TV, and get touch ONLINE help via chat.
God bless you
I can't turn the closed captioning off. I have went to device tv tried turning cc off. It won't turn off
If you are able to turn the closed captioning off with the original TV remote, then I suggest doing it that way. If you want that functionality on your Harmony One, you can use the original remote to teach the Harmony the closed captioning command. To learn commands, do the following:
1. Log in to the Harmony software. 2. On the "Devices" tab, click "Learn IR" next to the icon for your TV. 3. At the bottom of the screen where it says "MyNewCommand," enter the name that you want the command to have, and click "Learn." 4. Follow the on-screen instructions to learn the button. 5. Update your remote.
Samsung PN58b530 tv and harmony 550. When setup have all devices set except when the tv turns on it stays on one hdmi setup then jumps to another that was not programmed.
9helpful
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Magnavox energy saver projection tv-cannot remove closed caption
If you can bring up the FEATURES menu and can navigate with the Harmony remote scroll down the the CAPTIONS options. If you can turn display OFF then you should be all set.
If you do not have the manual for this set you can see it at:
http://www.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
Do you use a Home Theater receiver along with your televison?  Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver.  If it's set for the receiver, you need to change it to be associated with the TV.
Logitech Harmony 670 universal remote
Greetings Hendon,
The close captioning your looking for would have more to do your television or video source then your remote control.
Depending on how you receive your broadcasting you may want to make basic adjustments to your other equipment. If you receive it through your television you should check your television setup menu for something along the lines of "caption", "CC", or "Text". As well if you receive broadcasting through a cable or satellite box their setup menus should have options for similar options.
I hope this helps.
Jon
Go Ahead. Use Us.
Open Questions:
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
