Question about Dual Audio Players & Recorders
Where do I hook up my red and white cords to my amp on the back of my dual xdvd256bt deck?
Posted by Brayden on
5 Related Answers
ruanelectron
Ruan Noordman
  • 59 Answers
SOURCE: my tv only has a cable hook up how do i hook a dvd player with red white and yellow cords
put the tv on av
#yellow cord in yellow socket
#red cord in red socket
#white cord in withe socket
now power the dvd
#Yellow cord in yellow socket
there will be 2 places for the red and white cords
#the red and white cords must be inserted in the audio,
# you will see them next 2 each other
insert them you it will work.
For More Info Email To [email protected]
Posted on May 11, 2009
Sphynkter
Sphynkter
  • 221 Answers
SOURCE: THERE IS NOT 2 RCA HOOK UPS FOR THE SUBS HOW KAN I HOOK UP MY AMP SO MY 2 12S WILL HIT
If there's only a single sub-out RCA cable, you have two options. The amp may have a manual switch that puts it in Mono mode, in which case you only use 1 of the 2 RCA jacks. The other option is to go get an RCA splitter. This will take your single sub-out cable and feed the exact same signal to both left/right of your amp. Either way, you get the same result. If the 1200W amp is for your sub(s) only, you should set the high-pass filter and subsonic filters to help your bass "hit harder" and cleaner.
Posted on May 17, 2009
Anonymous
  • 140 Answers
SOURCE: I tried to hook up my dvd player and i get picture
That could be a result to that TV either not having the ports you need, or you may need different cords. On my TV. With the 360 they have two cords. Red,white, and yellow and also green blue and i think red but im not 100% sure. You may need to find a different port on your TV for your cords, or do what I do and have your VCR hooked up to your tv, and your DvD player hooked up thorugh your VCR. Hope this helps and don't forget to rate ^^
(and yes that yellow and white are a necessity)
Posted on Feb 23, 2010
A Miller
  • 8404 Answers
SOURCE: 120v hot tub wiring diagram
I would expect your tub is either 110 or 220. Currently you are set up for 110. Based on that ... you disregard the red wire.
If your tub can run on 220, you should run it on 220 as this is more economical.
You should probably have an electrician check this out and make any changes to assure proper and SAFE operation of your tub. You are using a GFI, correct?
Thanks for your interest in FixYa.com
Posted on May 16, 2010
Anonymous
  • 122 Answers
SOURCE: Installing Kenwood KDC-MP345U into a travel
the power terminals from the trailer arent direct connected to the battery terminals.when you are plugged to the mains the battery is charging and disconnect [via a relay perhaps]the orange terminal from batt+.try to make anew connection from the trailers battery terminals with a new fuse separated from all trailers circuit'use 2-2.5 mm*cables and a 15amps fuse.connect the yellow and red to+batt and black to- batt.
Posted on Jun 06, 2010
I have a 2008 Ford Fusion. I bought a Dual car stereo. Model XDVD256BT is there a wire harness that I can get to hook up to my car?
Yes. They sell them at walmart or a stereo install shop. We have webe audio here.they do auto starters.back up camaras.stereo.dvd.alarms etc etc.
Jun 03, 2017 | Ford Cars & Trucks
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
How do you hook up a sharp stereo cassette deck RT-W800
If that tape deck of yours has an audio line out jack (like the RCA red & white holes, usually located at the back), get an RCA plug to connect it to your stereo receiver's line in jack..... or
if that tape deck of yours doesn't have an audio line out jack but, instead, has phones (or headphones) jack (usually located at the side or front of the unit), then get a plug to connect it to your receiver's audio line in jack (RCA type, also coloured red & white).. Usually the plug is small so you may have to use an adapter for your tape deck's phones jack.
BOB (June 23rd '12 3:45am)
Apr 28, 2012 | Audio Players & Recorders
Connect Yamaha stereo cassette player KX 380 to htr-6025 receiver
HI RICHARD
To connect your cassette player to your receiver, you may have to use an RCA-type of plug (you know, the red & white plugs on both ends.
Apr 20, 2012 | Yamaha KX 390 Stereo Cassette Deck Single...
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
Installing Kenwood KDC-MP345U into a travel trailer. Trailer is pre-wired for deck. Have Orange (hot) & White (ground) from trailer converter to deck. Hooked up yellow (battery) wire from harness to...
Jun 05, 2010 | Kenwood Car Audio & Video
May 17, 2009 | Dual XDVD8182 Car DVD Player
My tv only has a cable hook up how do i hook a dvd player with red white and yellow cords
put the tv on av
now power the dvd
May 11, 2009 | GE 32GT740 32" TV
No remote on LXI series TV
I PURCHASE FROM A TV FROM A SALE AND I CAN'T HOOK UP THE DVD PLAYER AND I DON'T HAVE A REMOTE. THE OPT ARE CABLE AND AIR AND NOTHING WORKS WHEN I SWITCH IT OVER LIKE MY OTHER TV HELP.
Jul 31, 2008 | Rio Go Video DDV9475 Dual Deck VCR
How connect amplifire ??
You hook the amp up to the deck with rca cables red and white. you have output rca on the back of the deck also the blue wire labled remote also goes to the amp to turn it on and off.
Jul 19, 2008 | Blaupunkt London MP37 CD Player
79 people viewed this question
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
