The Element ELEFW328 is not a Smart TV. Thus it doesn't have any built-in network hardware (wired or wireless). You will need to add hardware to send the signal from your AirTV to your Element TV via one of the three HDMI ports. You could get the AirTV Play, AirTV Mini, Roku or other streaming box/stick. Set up this device to talk to your wi-fi and then the AirTV. Alternatively, you could try to mirror your Android or iOS AirTV display on your TV. If the device supports MHL (https://www.startech.com/en-us/faq/mhl-compliance) or Slimport, then you need the appropriate HDMI adapter/converter. Otherwise look at the ChromeCast or similar device to plug into your Element TV.
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Look in the manual that came with the TV.
It will tell you that you are trying to get a signal from a device that is NOT hooked up to your TV. You probably need to go to 'Input' with your remote, and work it so the 'Input' shows Cable, or Satellite, or DVR or whatever sends the signal to your TV.
The TV is smart enough to know there is no signal coming from the currently selected input.
Good luck.
When you receive the message with id and password, it usually means that either your phone is not multimedia messaging compatible or your account is not provisioned with the actual multimedia messaging feature itself. If unable to send or receive a picture message (MMS), troubleshoot accordingly:
Verify MMS is being sent to an AT&T subscriber. If MMS message is being sent to someone other then an AT&T wireless services subscriber, verify that the carrier is supported.
Picture messaging settings are pre-configured on all devices purchased from AT&T. If the settings have been altered or if the device was not purchased from AT&T, validate picture message settings are properly configured.
Attempt to send an MMS again.
If further assistance is required, please contact Customer Care.
If problems occur, please perform the following troubleshooting steps:
