Question about Boating
How do I remove the starter on a 1996 Polaris SL 700 jet ski
Posted by Anthony Rodrigues on
Kardoc
    Top Expert:
  • Boating Master
  • 6,083 Answers
5 Related Answers
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Posted on Mar 16, 2009
Anonymous
  • 207 Answers
SOURCE: removing starter w/out pulling motor kawasaki jet ski 750 ss
yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
Posted on Jun 27, 2009
nova2nv
Bill Linda Rivard
  • 197 Answers
SOURCE: My Polaris freedom(jet ski) starts and runs good
Replace exhuast temp sensor.
Posted on Nov 14, 2009
nova2nv
Bill Linda Rivard
  • 197 Answers
SOURCE: jet ski will run for about 5 minutes and then die out.
Exhaust temp sensor is telling computer to go into safe/limp mode.Check ALL of your engine cooling hoses,from the pump all the way up to the cyliders for debris/blockage.Most blockage happens at the pump or just where the hoses meet at the engine.
Posted on May 23, 2010
heimlich
David Belcher
  • 1978 Answers
SOURCE: ''how to replace starter in 1993 jet ski''
Unbolt the electronics box (swing out of the way), take off the box mount plate, and remove the exhaust upper manifold and expansion chamber. This should give you good access to the starter.
Posted on Sep 03, 2010
I picked up a 1995 sl 750 Polaris jet ski charged up a new battery but when I push the start button nothing happens
Try using a jumper from the battery directly to the starter, bypassing the switch. You may have a bad starter switch.
Feb 20, 2015 | ATVs
Why my Polaris sl900 1997 does have any sparks I changes the stator coil cdi box please help me
Check this site, (Disclaimer; I haven't used them, but it may have the PDF's that you'll need.)
http://www.kicksup.com/personalwatercraft/
Aug 22, 2014 | WSM 1996-1997 Polaris Sl 900 Cc Jet Ski...
Polaris troubleshooting
Have you cleaned the carbs and fuel tank , checked the plugs and coil ht's and connections ?
Aug 04, 2014 | WSM 1999-2000 Polaris Slh 700 Cc Jet Ski...
clean impellor and water intake ! run up on hose and check cooling ok !
Jul 28, 2014 | WSM 1993-1994 Polaris Sl 750 Cc Jet Ski...
Removing starter w/out pulling motor kawasaki jet ski 750 ss
Jun 15, 2009 | Boating
Mar 16, 2009 | Interactive Toy Concepts Polaris Sportsman...
Boating Logo
570 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
