Question about Generac Electrical Supplies
20kw Generac that has code 1501 ... what to do
Posted by connie m dunkum on
Terry
  • Generac Master
  • 11,377 Answers
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Generac Master
  • 35,825 Answers
Id check generacs website for an explanation of the code
Posted on Mar 23, 2018
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: generac 20kw - new battery dead, twice. is there a
if this is a standby unit. there is a charger built into the control box. check the fuses. if it still blows the d\fuse you can install a float type charger available from most auto parts stores. make sure there is power comming in from the bldg breaker box.
Posted on Aug 12, 2009
Testimonial: "what you say is correct, however, we have checked your suggestions and the unit still will not keep a charge. we have now put a trickle charge on it"
mycharmingli
Stormi Paulk
  • 415 Answers
SOURCE: battery does not stay charged on my 20kw generac
WAS A 110 VOLT CIRCUIT RAN TO IT FROM THE NORMAL UTILITY POWER OF HOME OR BUILDING IT FEEDS?
NORMALLY THIS IS DONE IN A SEPERATE CONDUIT FOR CONTROL WIRES.AND THE FEEDERS ARE IN ANOTHER CONDUIT.
WITH A DIGITAL TEST METER,CHECK FOR 120 VOLTS AT THE BATTERY CHARGER IN THE GENERATOR CABINET.USUALLY THERE IS A RECEPTICAL TO PLUG THE CHARGER INTO.
IF VOLTAGE IS PRESENT AT THE BATTERY CHARGER AND INDICATOR LIGHTS ARE ON, CHANGE METER TO DC AND CHECK FOR 13.8 VOLTS OUTPUT FROM THE BATTERY CHARGER.IF YOU HAVE OUTPUT VOLTAGE TO THE BATTERY,AND IT IS DEAD,CHANGE THE BATTERY..
HOPE THIS HELPS YOU,BEST OF LUCK.....
Posted on Nov 07, 2010
Brian Hamman
  • 85 Answers
SOURCE: I Am installing a Generac 20Kw air cooled unit
It is always good to install a large enough wire where the maximum load can be drawn plus a little extra for safety. 7 gauge wire will do, if it was mine I would use 6 gauge wire. If the length is over 20 feet but not longer than 80 feet go to the next larger size wire.
Posted on Dec 18, 2010
eugbug
EugenesDIYDen
  • 479 Answers
SOURCE: where can I get a operation and installation
Manuals can be downloaded from this webpage but the model number you quote doesn't give any results ?
http://www.generac.com/Service/ManualSearch/
Posted on Feb 22, 2011
Fred Yearian
  • 5603 Answers
SOURCE: i have a 2.5 liter
Look for a fuse that protects a transformer that supplies the rotating field voltage. If fuse is blown, find a rectifier module that the transformer drives. Likely the rectifier has a shorted diode. Fix before replacing the fuse.
Posted on Jun 28, 2011
Generac 20kw would not start due to rpm sensor error code 1505. how to fix and reset
please join the forum at zillerelectric.com ask there. they are great
Jul 08, 2017 | Generac Electrical Supplies
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Generac troubleshooting
Your battery is dead..If the controller has a visible display your battery charger is most likely OK. Just put in a new Group 26R battery and set the time etc.
Sep 07, 2014 | Generac Guardian 20kW Model : 5875
Have air cooled 20kw generac cranks but does not start
THERE SHOULD BE A LOW OIL SENSOR ONTHE SIDE OF THE MOTOR PLEASE MAY CAUSE THE MOTOR NOT TO START YOU SHOULD BEABLE TO JUMPER THE TWO WIRES ON THE SENSOR AND SEE IF THE GENERATOR WILL START
Apr 07, 2013 | Generac Guardian 20kW Model : 5875
Have a generac generator 20kw air coolded, automatic standy model 60511 that the battery goes dead all the time
how old is the battery? charge the battery then remove the negative cable place a test light between the battery and cable if the light is on you have a draw unplug things til the light goes out thats your draw
Oct 06, 2012 | Generac Electrical Supplies
Generac Model 5525-1 20kw air cooled standby generator Question: How do you access the battery? I think it is behind the front panel, but can't readily see how to open/remove the front panel. Thanks!
2 bolts on top of the front panel. Take them out and then just puul up and it come off. you can then easily remove the battery but make sure the leads dont touch as they still have charger power running through them.
Dec 04, 2010 | Generac Power Systems Generac 5525 20 Kw...
Electrical Supplies Logo
1,075 people viewed this question
Top Generac Electrical Supplies Experts
Bill Johnson
Fahr Quad
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
