A satin stitch is a combination of a wide zig-zag and a short stitch length. Set the stitch width to the maximum. Then while stitching, shorten the stitch length until the threads lay next to each other so no fabric shows between the threads but the threads do not overlap. It would help if you have a satin stitch foot so there is space under the presser foot for the extra threads.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Satin Stitch or Zig Zag Machine Applique stitch
Machine Appliqu Basics 1 Turning right angle corners with satin stitch
SOURCE: I need to satin stitch around the edge of a project
Try using the zig-zag setting, but adjust the stitch length to .3 or .4 (very small).
good luck!
SOURCE: on satin stitch setting, machine is only stitching left side
if the fabric is thin then it needs something with it to make it strong enough to handle the stitch,,I suggest trying a washable stabilizer or interfacing & see if that will help the stitch to be normal
