Lands Phones Logo
V
Vanessa Cullen Posted on Mar 22, 2018
I have a Samsung IDCS 28D and in the Display Area where the station name should appear there is a message that says BLANK MESSAGE.
4 Related Answers
Anonymous
  • 5 Answers
  • Posted on Nov 11, 2009
SOURCE: incoming calls
Yes that is correct
Anonymous
  • 532 Answers
  • Posted on Jun 07, 2010
SOURCE: The display on my Samsung iDCS 28D phone has gone blank.
hi,
if the display of your phone has gone bad, try do the following.
open the phone with a screw driver carefully.
after opening, find were the flex of the screen is connected to the phone panel.
make sure you fix the flex firm on the panel, then close the phone and switch it on.
if the problem continues, you will change the flex of the phone.
Anonymous
  • 213 Answers
  • Posted on May 04, 2011
SOURCE: I have the samsung idcs
Hi I am assuming that your are using the Samsung Voice Mail, if so to change the no answer greeting;
enter voicemail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voicemail message, you must press 3, delete the original message and reset the message followed by the #.
have uploaded a video off http://www.abbeytelecom.com which explains Voice-mail in more detail, if you are operating a differant system then I can only suggest that you rafer to the relevant operators manual
Anonymous
  • 213 Answers
  • Posted on May 25, 2011
SOURCE: We have a Samsung idcs
Hi Rachel, you need to remove your extension from the page groups, to do this;
press TRANSFER - 200 - 1234 - 1 - SPEAKER KEY
press 604.
using the 3rd softkey and your volume key when the cursor is under the 'members' find your extension number and press HOLD to delete yourself.
I have posted a video which actually shows how to add members to a group, this will give you an idea how to do the above, or for more tips go to http://www.abbeytelecom.com.
Hope that this helps
Why when I push my voicemail button, why do all the other phones ring?
This appears to be the phone, Samsung iDCS-28
https://www.pcliquidations.com/p1489-samsung-idcs-28d-falcon
This appears to be the Samsung 7100
https://www.samsung.com/us/televisions-home-theater/tvs/uhd-tvs/43--class-ru7100-smart-4k-uhd-tv--2019--un43ru7100fxza/
You have a phone connected to a television? Contact Samsung Support Direct. The phone doesn't have voicemail built in, so you are dialling your telco to get them. What you are pressing is a signal to ring the other phones.
Model idcs 28d. Why does it indicate 'message storage unit is full'?
Look for a 'message delete' button and try pushing it several times to clear storage.
My iDCS 28D phone has the correct date and time displayed, but when a voice message is received the date and time are incorrect on the message.
Must be bugg in the time set of your phone
• When the keyset is idle, press the TIMER button to start timing.
• Press the TIMER button again to stop timing.
• Read the elapsed time in the display.
• Lift the handset and replace it. The display will return to date and time.
How do you reset the password on a Samsung iDCS 28D
From the Subscriber Services Menu, Press [#] [7] [1] ....you will then hear the old password XXXXX you will be able to change it...
The Manual for a typical Samsung iDCS system is available here....
http://www.samsungidcsphonesystems.com/pdf files/idcs 16/iDCS_16_user_ins.pdf
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
