Question about Kodak Photography
Hi, I have a w730 Kodak pulse photo frame and after I connected to WiFi always keep showing that a mandatory update needs for the frame and write down what I need to do, but when I check It says no update available. Actually I dont care the update just I don't want it to show that reminder all the time instead of my pictures. I turned off the WiFi but it's just still showing just the reminder screen.
Posted by Gbor Szcs on
5 Related Answers
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: photo frame show
ummm get it from manufacture if you payed for software the key would be with the box this is not the site for hacked or cracked keys if you didnt pay for i suggest buy a copy
im not trying to be mean but this site is for help with things of every nature expect the piracy of software
Posted on May 16, 2008
erone47
Kenneth Obua
  • 458 Answers
SOURCE: my n73 always shows that my memory is full
you need to format your phone. try the soft format of *#7370# , if this doesnt work then do a hard format by folowing these steps
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold these 3 keys; Green dial key, * (star key) and no. 3 key and then press the power on/off to switch on the phone.
Do not let go all of the keys, hold until you see a formatting word screen show!
5. After a few minutes when the full phone formatting completed, your phone will be back to original system and factory setttings.
All applications installed will be lost unless you've made a backup on your mmc. You can restore the backup to the C drive again.
You should also try to save all your data on the mmc, that includes pics, mp3, videos ,games. avoid saving data on phone memory unless you have no memory card (mmc)
Formating phone will delete all your files in the phone memory so you should back up all your data before doig a full format
Posted on May 23, 2008
Anonymous
  • 5 Answers
SOURCE: kodak smart picture frame
Go here and follow the instruction -->
http://www.mv.com/ipusers/garbanzo/frame/smart-frame.html
Posted on Dec 07, 2008
Anonymous
  • 8 Answers
SOURCE: SmartParts SP1100B 11'' picture frame won't turn on
sounds like there was a power serge.  One of the suggestions would be to make sure you use the "safely Remove Hardware" tab on the tool bar.  The USB cable actually has power that goes through the line and can damage the flash memory in the picture frame.
your one hope would be to try another USB cable.
Posted on Mar 18, 2009
rickharriss
  • 3 Answers
SOURCE: vivitar digital photo frame VDF7
Select the folder you wish to show. Press enter to show the first slide then press enter again to bring up a tool strip.
Select the picture of slides to auto show the folder. You can adjust the speed in the tool box setting.
Posted on Jan 14, 2011
How do I reset the photo/frame numbers?
I'm afraid your camera can't set the photo count to 1.
At least the user manual does not show any possible hint how it could be done.
Feb 13, 2014 | Kodak EasyShare C913 Digital Camera
Kodak W730 Pulse is not finding any wireless networks
I'm having the same problem so I'm trying to re register it but need the activation cade since I don't have the box anymore and it won't come up on screen
Nov 16, 2013 | Kodak W730 PULSE Digital Frame
Kodak pulse wifi problems
either you are not entering you web key for the wifi correctly or you have not entered the activation code for the frame which can be found when you hold the heath check button on the back of the frame
Dec 29, 2012 | Kodak W730 PULSE Digital Frame
Kodak EasyShare W820 - Wireless network problems
This is supported by your provider not KODAK.
Pls. contact your internet provider
Sep 18, 2009 | Kodak Cameras
Will Not View All Pictures In Photo Directory
Take the camera and tag the pictures and select all of them and tag/ favorite and protect and tag some more directories you can create. That will delay transfering the pictures but all of them will transfer to files.
Vitally
Mar 01, 2009 | Kodak EasyShare EX1011 Digital Picture...
Kodak Easyshare 10" Frame - Photos won't save to frame
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Feb 20, 2009 | Kodak EasyShare EX1011 Digital Picture...
Kodak EasyShare software won't connect to digital photo frame
I had some problems with wireless connectivity with the Ex1011. It turned out to be the connection was breaking when I used WPA security. When I went to WEP it worked fine. My suspicion is that the router was changing the Key over time and the frame wasn't following it. So it would work for a while then stop. But also had trouble even seeing it at times. Anyway, worth a shot. You might try turning off security on the router altogether to see if it makes a difference. Good luck.
Dec 05, 2008 | Kodak EasyShare EX1011 Digital Picture...
Kodak smart picture frame
Can you access anything at all? Can you go on settings and stop the update automatically?
Nicholas
Jan 24, 2008 | Electronics - Others
Photography Logo
444 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
