Question about DISH Network Televison & Video
Where can I find information on programming my Yamaha RAV501 to my Dish Network Receiver?
Posted by Joe Silva on
Will
    Habit-Forming:
  • 91 Answers
You can use your Dish Network remote to control your Yamaha but not the other way around.
Posted on Mar 27, 2020
5 Related Answers
Jim Franks
  • 374 Answers
SOURCE: need codes for a phillips magnavox for dish network controller
Follow this link and got to the remote section. Once there shoose the type of remote you have and select remote codes to get the ones for that particular remote that may operate the piece of equipment desired. I hope this is of assistance to yoiu and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
Posted on Nov 11, 2008
Jim Franks
  • 374 Answers
SOURCE: got new remote and it won't work with my receiver, don't know how to program it
You probably just need to set the remote address on the remote to that on the receiver.
Press menu twice on the front panel of the receiver and you should be able to see the remote address displayed. If not just press and hold the SAT button down on the upper left of the remote until all lights light up across the top and release. Now key in 0-1 and press the pound sign. The SAT button will flash three times and now press the record button. You should now be able to control your programming and receiver. Thanks for using Fix Ya. If you need further he; let me know.
Posted on May 18, 2009
Anonymous
SOURCE: My dish network dvr625 tv2 remote will not work
Bring up the System Info screen (Menu 6-1-3, or System info button on front panel). On the lower right hand side you will see the address of the UHF (TV2) remote. On the new remote press and hold the SAT key 'till all the top buttons light once you release the button it should it flash. Then press the number on the key pad the receiver is set to, then the # key. The Sat key should flash three times locking the new code into the remote.
Posted on Jul 19, 2009
BeckiB_DISH
Becki Barned
  • 286 Answers
SOURCE: I HAVE DISH NETWORK RECEIVER #322 AND ON TV 2 I
Hello! My name is Becki Barned, and I am from Dish Network customer service. The problem that you are having is simple to fix. Although your remote works for the volume, and power, it is not working for the satellite. It does need to be reprogrammed. Just take it to tv1. With your tv1 remote, press the menu button twice. Then with the tv2 non-working remote, hold down the SAT button until all the mode lights light up at the top, then release. Then press the #9 on the remote keypad, then the pound (#) button, then record (above the number 3 on the keypad) 3 times. This should resolve your issue!!! If not, you can blog back, or find us on Twitter!!!!
Posted on Dec 24, 2010
CheriT Dish
Cheri Torres
  • 146 Answers
SOURCE: How do I program an Echostar 5.4 IR to control a
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post recently and wanted to see if I could help. The best codes for the 5.4 IR remote are 500, 578, 514 and 758. I will also list here for you the instructions for addressing your DISH remote to your Sony TV. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to email directly at [email protected] Thanks and have a great day!
Instructions for addressing remote to TV.
  1. Turn the Television On
  2. Press and Hold the TV Mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound (#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Posted on Feb 24, 2011
Do i need to program my remote to change channels on the dish network
Hey knapshak, Tommy Faust with DISH Network here. It would need to be programmed to the receiver in order to change programming. You can do that by following the steps below.
1. Access System Information screen from your main TV.
2. Note the number on the bottom of screen next to Remote Address.
3. Hold SAT until all buttons on top light up then release.
4. While SAT is blinking enter a number between 1-15 and press # (Different from number listed)
5. Press record 3 times and the number should change, try the remote and see if you can change channels.
You can also check out this link for more information:
http://www.dishnetwork.com/SupportSection/remote-setup
Tommy Faust
DISH Network
Mar 19, 2011 | DISH Network IR Remote Control
Remote control code
thegoi_16
I can provide you with instructions and codes for DISH Network equipment. I have provided a link with this information. If you have DISH Network equipment, select your receiver model and follow the instructions. At the bottom of the page are links for your receiver model with the TV codes for programming the remote. I hope this helps.
Ray Calo
DISH Network
Mar 03, 2011 | Televison & Video
Describe your yamaha receiver codes for dish Problem i need a code to let the Dish Network remote to work with the receiver
Try this link it should have all of the codes and istructions for programming our remotes.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
Dec 15, 2010 | Yamaha RX-V663 Receiver
Yamaha receiver mdl RX-V367. What code will let it work with the Dish Network remote?
Here are the codes for your Yamaha RX-V367: 733, 663, 732,747, 730, 731, 745, 848, 847, 657, 786, 684, 849, 655, 823, 841, 646, 650, and651.
Step 1:
Press and hold the AUX button until all mode button back lights come on, thenrelease.
Step 2:
Press 2, and then enter the device code corresponding to the equipment (listedabove).
Step 3:
Press the POUND (#) button. If the code entered is valid for the remote, themode light flashes three times. Try using the DISH remote to control the component,if it doesn't work with one code try another.
Although we try and facilitate a one remote solution, wecannot guarantee that our codes with work for all brands and models components.Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Support Representative
I FORGOT MY CODE ON MY UNIVERSAL REMOTE TO MY 301 RCA DISH NETWORK RECEIVER
Can you please provide more information to allow us to further assist you, for example could you please let us know the manufacturer of your universal remote? Also just to confirm, are you trying to program the remote to your television, or are you trying to program the remote to your 301 receiver? Or is it both? In addition, you may also be able to contact the manufacturer of your universal remote if you'd like and they can also provide further assistance in regards to the remote codes you are requesting for the remote if they are not included in the instruction manual that came with the remote.
-Kirstie DISH Network
Sep 09, 2010 | DISH Network 301 DTV Receiver
I bought a Dish remote for a2nd tv and cant get it
strmason,
Are you still having problems with programming the remote to your receiver? I am assuming it is TV 1? You should have a green tab at the bottom of the remote with a "green 1" and no lettering after the 1. If you have the correct tab on the bottom, you should be on the "System Information" screen, showing on your TV, from the receiver. At the bottom of the screen you will have "primary and secondary remote addresses" with numbers in the white boxes. You can press the "record" button on the remote to address the remote to the receiver. I hope this helps.
Ray Calo
DISH Network
May 14, 2010 | DISH Network 322 DTV Receiver
I would like to control my Yamaha RX V563 amplifier with my dish remote control.
You should be able to find remote codes and instructions for programing them on the dish network or direct tv websites
Apr 18, 2010 | Yamaha RX-V663 Receiver
Satellite Receiver to Yamaha Receiver
It sounds like either on the 612 or the Yamaha Receiver that the HDMI port is faulty, thus causing the flashing picture. It sounds like the 612 to the TV works fine. I would recommend replacing the Yamaha, and if problem persists then try replacing the 612.
Mar 18, 2010 | DISH Network ViP 612
Televison & Video Logo
89 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
