Question about NorStar Lands Phones
I want to turn off the ringer on my personal office phone for all 6 lines on my handset. They are land lines.
I have a Meridian Norstar model 7208
Posted by timothy runyon on
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: meridan 7208 help please
Usually Meridian phones are hooked up to telephone switching boxes in the back of the office. There designed for non analog phone lines.
Nortel does make home phones that are really good to use. Check their website out.
www.nortel.com
Posted on Jul 29, 2008
Anonymous
SOURCE: Our office has 13 phones
You will have to go into system programming, under sets, line appearances. You will need to set the lines on the phones to appear and ring, not just appear.
Posted on Jan 03, 2009
consultel1
george peters
  • 860 Answers
SOURCE: Find free complete user manual for 7310 Meridian Norstar system
The 7310 is a phone model number. The system is going to be a CICS, MICS, or a BCM. If you look on the top corner of the box it should be there. Once you find out the model go to http://pdf.textfiles.com/manuals/TELECOM-F-R/
that should help with documentation.
Posted on Feb 13, 2009
Anonymous
  • 211 Answers
SOURCE: What is a Norstar Overlay Template?
right top Show
right bottom Next
left top Heading
left bottom Back
Posted on Mar 23, 2009
terry gormley
  • 52 Answers
SOURCE: We have a Norstat Meridian M7310 phone system - is
THE PHONE IN THE BACK IS THIS A NORSTAR PHONE. WHAT IS THE QWEST VMAIL AND WHAT DOES THE NORSTAR SYSTEM LOOK LIKE . SOUNDS TO ME THAT QWEST IS SUPPLING VMAIL AND NOT YOU OWEN NORSTAR COULD YOU CLARIFY THIS FOR ME.
Posted on Dec 22, 2009
How can I program an all call button on the NorStar Meridian M7310 Phone to intercom everyone in the office simultaneously?
I guess you want a page key programmed on your set. press feature *3, press a memory key, press feature 610. This key pages all sets when pressed.
Meridian M8X24-DS System Problem - All handsets are blinking on all lines
Sounds like a defective software cartridge
try a swap and see if flashing stops
Meridian phone ringer too loud
You can adjust the ringer of your Nortel phone by dialing Feature *6, then using the volume bar to adjust the ringer while the tone is playing, or dial Feature *80 to adjust it there.
Norstar Meridian how to turn on the ringer
From the following web site:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Norstar meridian 7208 won't ring.
Does it ring when you move it to a known ringing port? Is it programmed to ring (Terminals & Sets) Appear and Ring? Do you have Automatic Set Relocation turned on so the extension number stays with the phone?
There are a lot of features to check for ringing, including the volume of the set.
Carl
Incoming calls on Line 4 are ringing in personal office and mail line. I want it only to ring on Mail line . Our phone is a Norstar M7310. Thanks Sherrie
Enter Feature **2663444
Search through General Options until you find Ringing options.
Type in the extension number of your personal office.
scroll to line 4 choose turn ringer to off, and rls! Let me know if you need clarification on how to find Ringers in General Options.
Installed this NT9K08AD03 where a NT8B30AD03 was and the new phone does not work. Meridian Compact ICS 2.0
The M2008 set (NT9K08AD03) doesn't work on a CICS system. It works with the Meridian PBX systems. The type of sets that work with a Compact ICS system are M 7100, 7208, 7310, 7324 and T 7100, 7208, 7316, 7316e as well as some of thier cordless sets.
Turn ringer on T7316
T7316 Manual
The volume control adjusts the handset, hands free, headset, and ringer volume. Someone may have fiddled with the buttons and turned the ringer down enough that it doesn't sound when a call is incoming.
2answers
Meridan 7208 help please
Dear sheryl498,
Your phone is designed for a PBX (Private Branch Exchange) unit like the Compact ICS or the 6x16 TCU that was at the office. It is not compatible with regular POTS lines or standard home lines.
Lands Phones Logo
Top NorStar Lands Phones Experts
Oloyede Monsuru
Ekse
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
