Televison & Video Logo
phil williams Posted on Mar 21, 2018
My JVC soundbar won't work with my philips tv after disconnection please help
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on May 08, 2008
SOURCE: Jvc TV
0053 is the code for JVC.
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Anonymous
  • Posted on May 18, 2009
SOURCE: I bought a used Philips tv, model # ocv625c123 ,
I found the switch on my SAT box to switch it fro m ch 3-4. I still don't know why the tv won't go to ch 3. But it doesn't matter now.
Jim Pattison
  • 1004 Answers
  • Posted on Jun 05, 2014
SOURCE: Connect Sound Bar to TV (flatscreen - Proscan)
How about fiber optic cable or composite cables. I usually recommemd that people do either of these.
rhodesworks
  • 3159 Answers
  • Posted on Mar 15, 2015
SOURCE: I just bought the Philips Soundbar w/subwoofer HTL2160/F7 2012 and i connected the red&white audio cables (left-right) from the soundbar to my Emerson 55" plasma screen tv but there is no audio. It wo
Be sure you have connected the audio OUT jacks from the TV to the audio IN jacks on the sound bar. People often connect them to the wrong jacks.
rabbitbrains
Rabbit Brains
  • 575 Answers
  • Posted on Feb 10, 2016
SOURCE: I have a Samsung soundbar connected to my TV. Sound is working fine through the optical cable. But when I connect the soundbar to Bluetooth there is no sound at all. Please help.
Try pressing and holding the Bluetooth button on the sound bar, that will put it in search mode. Once it detects the Bluetooth device it will connect.
What is the best way (cable) to connect my JVC TV Model LT-42N530A to a soundbar?
That really depends on what connections are on both the TV and the soundbar. Optical connections provide the best sound quality, but your TV and soundbar may not have that connection. Your manual for your JVC should show you all the different ways you can connect that. I would compare that to your TV's connections and look up the quality of the signal for all the connectors that match both. Hope that helps.
Is it easy to set up soundbar up to an x box 1? I'm just gunna settle for the soundbar to be used when gaming or using DVDs ect throu the x box.
Connecting your xbox one console to a sound system. this setting allows you to adjust how much the volume change on your tv using the volume up or down.
No sound via philips soundbar hts8100 with philips 52pfl7403d tv
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
2answers
My soundbar won't turn on. It was working fine and just stopped.
Same here ?? I repair computers from home and did basic troubleshooting to no avail
Soundbar wont work
It basically has an Optical input, or a coaxial input. Use whichever input is available for you from your TV digital output, to the soundbar. If it still doesn't work, the soundbar is probably damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
1helpful
2answers
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
